Salta al contenuto principale
HP EliteBook x360 1030 G3 Fan Replacement
Pablo Arriola
Pablo Arriola e 3 altri collaboratori
Ultimo aggiornamento il December 9, 2023
8 minuti
Facile
Introduzione
Vai al passo 1
If your laptop is overheating and there is no fan noise, it may be in need of a fan replacement. Follow these steps to do so.
Cosa ti serve
Strumenti
Mostra di più…
  1. HP EliteBook x360 1030 G3 Fan Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Fan Replacement: passo 2, immagine 1 di 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Fan Replacement, Fan: passo 3, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the four 3.5 mm screws near the middle of the fan assembly.
    • Use the same screwdriver to remove the remaining five 3.9 mm screws.
  4. HP EliteBook x360 1030 G3 Fan Replacement: passo 4, immagine 1 di 3 HP EliteBook x360 1030 G3 Fan Replacement: passo 4, immagine 2 di 3 HP EliteBook x360 1030 G3 Fan Replacement: passo 4, immagine 3 di 3
    • Before pulling the fan out, identify the two wires that are connected to the fan and to the motherboard.
    • For each, use plastic opening tool to lift the black wire housing upward out of its port.
    • Be sure not to pull the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Fan Replacement: passo 5, immagine 1 di 2 HP EliteBook x360 1030 G3 Fan Replacement: passo 5, immagine 2 di 2
    • Slide the fan assembly toward you, and when the top edge of the fan is out of the vent grill, the fan is completely removed.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team S2-G9, Maness Spring 2019 Membro di Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 64
Tutti i Tempi: 4,819
