Salta al contenuto principale
HP EliteBook Folio 1020 G1 Display Replacement
Steven Duke
Steven Duke e un altro collaboratore
Ultimo aggiornamento il May 17, 2023
25 minuti
Moderato
Testo Confuso
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
Is your HP EliteBook Folio 1020 G1 screen not turning on, or the display is shattered? If so, here is a guide to fix the problem by replacing the faulty display.
Before taking any part of the computer apart, please remember to power down your computer and unplug the power cable from any power source. Failure to do so could harm yourself or the computer, so these precautions must be taken. Also, when replacing a screen display, there is a chance that the glass could shatter. Please take precautions for the glass.
In order to remove the bezel from the display, the iOpener tool is used. To learn how to use the iOpener, follow the instructions here: iOpener Instructions.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. HP EliteBook Folio 1020 G1 Display Replacement, Lower Case: passo 1, immagine 1 di 1
    • Use a TR8 Torx screwdriver to remove:
    • Six 5.3 mm screws
    • Four 3.3 mm screws
  2. HP EliteBook Folio 1020 G1 Display Replacement: passo 2, immagine 1 di 1
    • Use a nylon spudger to gently pry the lower case up and off.
  3. HP EliteBook Folio 1020 G1 Display Replacement, Battery: passo 3, immagine 1 di 2 HP EliteBook Folio 1020 G1 Display Replacement, Battery: passo 3, immagine 2 di 2
    • Gently pull and free the battery's bundled cable connector that leads from the battery to the motherboard.
  4. HP EliteBook Folio 1020 G1 Display Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #1 screwdriver to unscrew and remove the six 4 mm screws that secure the battery.
  5. HP EliteBook Folio 1020 G1 Display Replacement, Motherboard: passo 5, immagine 1 di 2 HP EliteBook Folio 1020 G1 Display Replacement, Motherboard: passo 5, immagine 2 di 2
    • Remove:
    • Eight 4.6 mm screws shown in the circles using Phillips #0.
  6. HP EliteBook Folio 1020 G1 Display Replacement: passo 6, immagine 1 di 3 HP EliteBook Folio 1020 G1 Display Replacement: passo 6, immagine 2 di 3 HP EliteBook Folio 1020 G1 Display Replacement: passo 6, immagine 3 di 3
    • Disconnect the keyboard connections from the motherboard.
    • Disconnect by lifting the underside of the white tabs with a spudger.
  7. HP EliteBook Folio 1020 G1 Display Replacement: passo 7, immagine 1 di 3 HP EliteBook Folio 1020 G1 Display Replacement: passo 7, immagine 2 di 3 HP EliteBook Folio 1020 G1 Display Replacement: passo 7, immagine 3 di 3
    • Disconnect circled terminals. Disconnect by lifting the underside of white tabs with spudger.
  8. HP EliteBook Folio 1020 G1 Display Replacement: passo 8, immagine 1 di 3 HP EliteBook Folio 1020 G1 Display Replacement: passo 8, immagine 2 di 3 HP EliteBook Folio 1020 G1 Display Replacement: passo 8, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Remove the circled tabs by pulling on the white support edges backward with a pair of tweezers.
  9. HP EliteBook Folio 1020 G1 Display Replacement: passo 9, immagine 1 di 3 HP EliteBook Folio 1020 G1 Display Replacement: passo 9, immagine 2 di 3 HP EliteBook Folio 1020 G1 Display Replacement: passo 9, immagine 3 di 3
    • Gently pull on the black pull tab on the top of the connector.
    • For the wires going to the Wi-fi card, remove both wires going to the top of the card using the tweezers.
  10. HP EliteBook Folio 1020 G1 Display Replacement: passo 10, immagine 1 di 2 HP EliteBook Folio 1020 G1 Display Replacement: passo 10, immagine 2 di 2
    • Lift the now disconnected motherboard from the side shown in image 1. This side must be lifted to not damage the ports. The disconnected motherboard (aside from port removed in step 12) is shown in image 2.
  11. HP EliteBook Folio 1020 G1 Display Replacement, Display: passo 11, immagine 1 di 3 HP EliteBook Folio 1020 G1 Display Replacement, Display: passo 11, immagine 2 di 3 HP EliteBook Folio 1020 G1 Display Replacement, Display: passo 11, immagine 3 di 3
    • To release the display frame from the lower frame, remove:
    • Six 4.1 mm screws using Phillips #0.
  12. HP EliteBook Folio 1020 G1 Display Replacement: passo 12, immagine 1 di 2 HP EliteBook Folio 1020 G1 Display Replacement: passo 12, immagine 2 di 2
    • Once the screen is separated from the bottom frame, use a plastic opening tool to remove the bottom trim from the screen.
  13. HP EliteBook Folio 1020 G1 Display Replacement: passo 13, immagine 1 di 2 HP EliteBook Folio 1020 G1 Display Replacement: passo 13, immagine 2 di 2
    • Using the iOpener and spudger, work around the screen bezel to remove it.
  14. HP EliteBook Folio 1020 G1 Display Replacement: passo 14, immagine 1 di 2 HP EliteBook Folio 1020 G1 Display Replacement: passo 14, immagine 2 di 2
    • To remove the screen, remove:
    • Four 2.2 mm screws using Phillips #0.
  15. HP EliteBook Folio 1020 G1 Display Replacement: passo 15, immagine 1 di 1
    • Lift display from the frame.
Conclusione
Steven Duke
Membro da: 03/28/23
121 Reputazione
1 Guida realizzata
IUPUI, Team 2-1, Harley Spring 2023 Membro di IUPUI, Team 2-1, Harley Spring 2023
IUPUI-HARLEY-S23S2G1
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 267
