Salta al contenuto principale
HP EliteBook Folio 1020 G1 CMOS Battery Replacement
Drew Borden
Drew Borden e 3 altri collaboratori
Ultimo aggiornamento il March 7, 2023
10 minuti
Moderato
Introduzione
Vai al passo 1
If you lose BIOS settings on startup or your CMOS battery is reaching the end of its lifetime, then the battery must be replaced. This is a guide to replacing the CMOS battery of your computer. In order to replace it, the back cover of the laptop must be removed to expose the cable which secures the battery and the battery itself.
Before replacing the component, please remember to power down and unplug your computer to avoid any power surges or shorts. Failing to power down and disconnect the power cable may result in further harm to the laptop or even yourself, so precautions must be taken.
Note: When the CMOS battery is removed, BIOS settings will be reset to factory defaults.
Cosa ti serve
Ricambi
Strumenti
  • TR8 Torx Security Screwdriver
  • Spudger
    Spudger
Mostra di più…
  1. HP EliteBook Folio 1020 G1 CMOS Battery Replacement, Lower Case: passo 1, immagine 1 di 1
    • Use a TR8 Torx screwdriver to remove:
    • Six 5.3 mm screws
    • Four 3.3 mm screws
  2. HP EliteBook Folio 1020 G1 CMOS Battery Replacement: passo 2, immagine 1 di 1
    • Use a nylon spudger to gently pry the lower case up and off.
  3. HP EliteBook Folio 1020 G1 CMOS Battery Replacement, CMOS Battery: passo 3, immagine 1 di 1
    • Unplug white plug that leads from the CMOS battery to the motherboard.
  4. HP EliteBook Folio 1020 G1 CMOS Battery Replacement: passo 4, immagine 1 di 1
    • Carefully pull out the CMOS battery.
    • The CMOS battery is attached to the case with adhesive, so you must pull hard enough to surpass this connection.
Conclusione
Drew Borden
Membro da: 03/22/22
606 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,657
