Salta al contenuto principale
HP EliteBook 835 G7 Battery Replacement
Cosa ti serve
  1. HP EliteBook 835 G7 Battery Replacement, Remove the Phillips screws: passo 1, immagine 1 di 2 HP EliteBook 835 G7 Battery Replacement, Remove the Phillips screws: passo 1, immagine 2 di 2
    • Completely power off and unplug your EliteBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a Phillips screwdriver to loosen the five captive screws from the lower case.
  2. HP EliteBook 835 G7 Battery Replacement, Release the case's right clips: passo 2, immagine 1 di 3 HP EliteBook 835 G7 Battery Replacement, Release the case's right clips: passo 2, immagine 2 di 3 HP EliteBook 835 G7 Battery Replacement, Release the case's right clips: passo 2, immagine 3 di 3
    • Insert an opening pick between the lower case and the chassis along the hinge edge.
    • Slide the opening pick around the right corner and halfway up the side of the EliteBook to release the clips securing the lower case.
  3. HP EliteBook 835 G7 Battery Replacement, Release the case's left clips: passo 3, immagine 1 di 3 HP EliteBook 835 G7 Battery Replacement, Release the case's left clips: passo 3, immagine 2 di 3 HP EliteBook 835 G7 Battery Replacement, Release the case's left clips: passo 3, immagine 3 di 3
    • Repeat the previous step on the left side of the case to release the clips.
  4. HP EliteBook 835 G7 Battery Replacement, Remove the lower case: passo 4, immagine 1 di 3 HP EliteBook 835 G7 Battery Replacement, Remove the lower case: passo 4, immagine 2 di 3 HP EliteBook 835 G7 Battery Replacement, Remove the lower case: passo 4, immagine 3 di 3
    • Lift the lower case up and away from the EliteBook and remove it.
  5. HP EliteBook 835 G7 Battery Replacement, Move the pull tab: passo 5, immagine 1 di 3 HP EliteBook 835 G7 Battery Replacement, Move the pull tab: passo 5, immagine 2 di 3 HP EliteBook 835 G7 Battery Replacement, Move the pull tab: passo 5, immagine 3 di 3
    • Move the pull tab that covers the battery connector out of the way.
    • You can use a piece of tape to hold the pull tab out of the way.
  6. HP EliteBook 835 G7 Battery Replacement, Disconnect the battery: passo 6, immagine 1 di 3 HP EliteBook 835 G7 Battery Replacement, Disconnect the battery: passo 6, immagine 2 di 3 HP EliteBook 835 G7 Battery Replacement, Disconnect the battery: passo 6, immagine 3 di 3
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  7. HP EliteBook 835 G7 Battery Replacement, Reroute the speaker cable: passo 7, immagine 1 di 3 HP EliteBook 835 G7 Battery Replacement, Reroute the speaker cable: passo 7, immagine 2 di 3 HP EliteBook 835 G7 Battery Replacement, Reroute the speaker cable: passo 7, immagine 3 di 3
    • Use a spudger, or your fingers, to separate the speaker cable from its plastic recess.
    • Repeat for the two other plastic recesses.
  8. HP EliteBook 835 G7 Battery Replacement, Unfasten the battery: passo 8, immagine 1 di 2 HP EliteBook 835 G7 Battery Replacement, Unfasten the battery: passo 8, immagine 2 di 2
    • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the battery.
  9. HP EliteBook 835 G7 Battery Replacement, Remove the battery: passo 9, immagine 1 di 3 HP EliteBook 835 G7 Battery Replacement, Remove the battery: passo 9, immagine 2 di 3 HP EliteBook 835 G7 Battery Replacement, Remove the battery: passo 9, immagine 3 di 3
    • Tilt the top of the battery upward to release its plastic clips.
    • Remove the battery.
Conclusione
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
Membro da: 01/16/22
127.731 Reputazione
592 Guide realizzate
iFixit Membro di iFixit
Staff
141 Membri
17.895 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 21
Tutti i Tempi: 310
