HP EliteBook 820 G3 Keyboard Replacement
Introduzione
Vai al passo 1This guide will show you how to replace the keyboard for the HP EliteBook 820 G3 laptop. If any of the keys do not work or the small track pad on the keyboard does not work, the keyboard will need to be replaced. Before beginning, power off the device and disconnect any external power supply.
Cosa ti serve
Remove the two 3.4 mm keyboard screws found near the fan and on top of the hard drive using a Phillips #00 screwdriver.
Altre 4 persone hanno completato questa guida.
