Salta al contenuto principale
HP EliteBook 755 G5 Battery Replacement
Max Kletskov
Max Kletskov
Ultimo aggiornamento il September 18, 2024
Nessuna stima
Moderato
Introduzione
Vai al passo 1
How to replace the battery of a HP EliteBook 755 G5 laptop. The images and information in this guide were taken from this computer's service manual.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
    • Turn off the computer. If you are unsure whether the computer is in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
  1. HP EliteBook 755 G5 Battery Replacement, Remove the bottom cover: passo 2, immagine 1 di 2 HP EliteBook 755 G5 Battery Replacement, Remove the bottom cover: passo 2, immagine 2 di 2
    • Turn the computer upside down on a flat surface.
    • Loosen the eight captive screws that secure the bottom cover.
    • Loosen the two inset captive screws that secure the bottom cover.
    • Starting under the middle of the display, pry and lift the bottom cover off the computer.
  2. HP EliteBook 755 G5 Battery Replacement, Disconnect the battery: passo 3, immagine 1 di 1
    • Disconnect the battery cable from the system board.
    • Remove the four Torx T8 2.0×4.0 screws.
  3. HP EliteBook 755 G5 Battery Replacement, Remove the battery: passo 4, immagine 1 di 1
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
Conclusione
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
Membro da: 04/22/20
40.850 Reputazione
16 Guide realizzate
The Home Depot Membro di The Home Depot
Community
18.029 Membri
140 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 45
Tutti i Tempi: 1,453
