Salta al contenuto principale
HP EliteBook 1050 G1 Keyboard Panel Replacement
Ming-chin Wu
Ming-chin Wu e 4 altri collaboratori
Ultimo aggiornamento il April 1, 2024
10 minuti
Facile
Introduzione
Vai al passo 1
This guide will show the reader how to replace the keyboard panel on the HP EliteBook 1050 G1. The keyboard panel is used to type letters on the computer screen. The keyboard replacement is not very difficult, so it has been labeled as "easy", and this task only takes about 10 minutes to complete. To prevent any danger, the battery has been removed. The tools required are shown in the section named "what you need" located to the right of the introduction.
Cosa ti serve
Strumenti
Mostra di più…
  1. HP EliteBook 1050 G1 Keyboard Panel Replacement, Motherboard: passo 1, immagine 1 di 2 HP EliteBook 1050 G1 Keyboard Panel Replacement, Motherboard: passo 1, immagine 2 di 2
    • Remove the two 5.5mm screws with a Torx T8 driver.
    • Remove the five 8.7mm screws with a Torx T8 driver.
    • Remove the two 6.6mm screws with a Torx T8 driver.
    • Pry open the backplate with a Jimmy.
  2. HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 2, immagine 1 di 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 2, immagine 2 di 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 2, immagine 3 di 3
    • Remove the two 1.9mm screws from the SSDs with a Phillips #0 driver.
    • Disconnect the two PCIe SSDs by sliding them out of each port.
  3. HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 3, immagine 1 di 2 HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 3, immagine 2 di 2
    • Pull the clips on either side of the RAM chip away from each other using your fingers.
    • As you pry apart the clips, the RAM should pop up to rest at an angle to the motherboard.
    • Slide the RAM chips out of their respective slots.
  4. HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 4, immagine 1 di 2 HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 4, immagine 2 di 2
    • Remove eight 4.5 mm screws from the battery with a Phillips #1 screwdriver.
    • Disconnect the white tipped battery cable from the motherboard.
  5. HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 5, immagine 1 di 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 5, immagine 2 di 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 5, immagine 3 di 3
    • Remove the six 4.5mm screws from the fan assembly using a Phillips #00 screwdriver.
    • Unscrew four 3.6mm screws from the heatsink assembly with a Phillips #00 screwdriver.
    • These "captive" screws are connected to the heatsink and will not detach from it.
    • Remove the fan assembly.
  6. HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 6, immagine 1 di 1
    • Unplug the seven ZIF connecters from the motherboard by flipping up the black switches with a spudger and pulling out the cables.
  7. HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 7, immagine 1 di 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 7, immagine 2 di 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 7, immagine 3 di 3
    • Remove two 1.9mm screws from the display cable bracket using a Phillips #00 driver.
    • Remove the two connectors on the right side gently.
    • Remove the connector on right side of motherboard.
    • Remove the three 4.5mm screws using a Phillips #00 driver and remove the bracket.
    • Remove the two coaxial cables.
  8. HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 8, immagine 1 di 2 HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 8, immagine 2 di 2
    • Remove the two 3mm screws using a Phillips #00 driver.
    • Remove the motherboard by lifting it up and out of the case.
  9. HP EliteBook 1050 G1 Keyboard Panel Replacement, Keyboard Panel: passo 9, immagine 1 di 3 HP EliteBook 1050 G1 Keyboard Panel Replacement, Keyboard Panel: passo 9, immagine 2 di 3 HP EliteBook 1050 G1 Keyboard Panel Replacement, Keyboard Panel: passo 9, immagine 3 di 3
    • Peel back the black cover on the keyboard.
  10. HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 10, immagine 1 di 1
    • Remove all 52 screws from the keyboard panel using a Phillips #000 screwdriver.
  11. HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 11, immagine 1 di 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 11, immagine 2 di 3 HP EliteBook 1050 G1 Keyboard Panel Replacement: passo 11, immagine 3 di 3
    • Remove the keyboard panel from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 952
