HP Compaq nc6400 Bluetooth Module Replacement
Introduzione
Vai al passo 1This guide will take you through the process of replacing the bluetooth module in an HP Compaq nc6400 Laptop. You will need the correct replacement bluetooth module for your laptop to complete the installation.
Cosa ti serve
Locate the lock labeled two at the bottom right corner below the battery.
Slide and hold the lock to the left.
Flip the computer top down and locate the second to-the-right 1.2 Philips #1 screw in the bottom-left corner.
Remove the screw.
Altre 3 persone hanno completato questa guida.
1Commento della guida
Hi,
My HP nx9420 did not have the Bluetooth. I wish to install one. I got one from my old HP nx9420. it Part Number is 397922-001 but the actual laptop says it requires the 409993-001 are these module the same ?
thanks
Alain
