HP Compaq Presario cq62-214nr Motherboard Replacement
Introduzione
Vai al passo 1In this guide it will take you through the process of replacing the motherboard. Please make sure the screws from the prerequisite guides are removed.
Cosa ti serve
With all the screws removed from the previous guides. Remove the final eight M2.5X5 mm Philips screws on the back of the laptop
Remove the four M2.5x5 mm Phillips screws from the exposed keyboard cover.
Altre 3 persone hanno completato questa guida.
