Salta al contenuto principale
HP Compaq CQ58-bf9WM Battery Replacement
Liberty Wilson
Liberty Wilson e 2 altri collaboratori
Ultimo aggiornamento il June 26, 2017
1 minuto
Molto facile
Introduzione
Vai al passo 1
This will help to replace the computer's battery pack.
  1. HP Compaq CQ58-bf9WM Battery Replacement, Battery: passo 1, immagine 1 di 3 HP Compaq CQ58-bf9WM Battery Replacement, Battery: passo 1, immagine 2 di 3 HP Compaq CQ58-bf9WM Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Place thumb on the battery switch and push to slide. The battery will eject.
    • Replace and discard old battery with a new working battery.
Conclusione
pop battery back into place- no tools required
1Commento della guida
can you help me please? I have a Compaq cq58 and the battery is jammed in, as the battery release button hasn’t flipped back to where it should be. It won’t budge and i need to get the battery off as i have to change the screen - and don’t want any power getting to any of the laptop components!
cliff pooley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,499
