Salta al contenuto principale
HP Compaq C700 Touchpad Replacement
Taylor Johansen
Taylor Johansen e 5 altri collaboratori
Ultimo aggiornamento il May 7, 2024
1 ora
Difficile
Introduzione
Vai al passo 1
To remove the touchpad, you must remove other components to get to it such as the keyboard.
Cosa ti serve
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. HP Compaq C700 Touchpad Replacement, Keyboard: passo 1, immagine 1 di 1
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Touchpad Replacement: passo 2, immagine 1 di 3 HP Compaq C700 Touchpad Replacement: passo 2, immagine 2 di 3 HP Compaq C700 Touchpad Replacement: passo 2, immagine 3 di 3
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
    There is a 3rd screw under ram door
    Noah Galegor - Replica
  3. HP Compaq C700 Touchpad Replacement: passo 3, immagine 1 di 1
    • Gently lift up and remove the keyboard.
  4. HP Compaq C700 Touchpad Replacement, Touchpad: passo 4, immagine 1 di 1
    • Locate the twenty 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver.
  5. HP Compaq C700 Touchpad Replacement: passo 5, immagine 1 di 1
    • Remove the hard drive by pulling on the plastic tab and lifting upward.
  6. HP Compaq C700 Touchpad Replacement: passo 6, immagine 1 di 1
    • Locate and unscrew the two Phillips head 3 mm screws on the wireless card.
  7. HP Compaq C700 Touchpad Replacement: passo 7, immagine 1 di 1
    • Unhook the two wires connecting to the wireless card by gently pulling them out.
  8. HP Compaq C700 Touchpad Replacement: passo 8, immagine 1 di 1
    • Gently lift and pull out the card.
  9. HP Compaq C700 Touchpad Replacement: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Locate the power button connector wire.
    • Using the tweezers, unhook the wire.
  10. HP Compaq C700 Touchpad Replacement: passo 10, immagine 1 di 2 HP Compaq C700 Touchpad Replacement: passo 10, immagine 2 di 2
    • Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
  11. HP Compaq C700 Touchpad Replacement: passo 11, immagine 1 di 3 HP Compaq C700 Touchpad Replacement: passo 11, immagine 2 di 3 HP Compaq C700 Touchpad Replacement: passo 11, immagine 3 di 3
    • Unplug the remaining wires using the tweezers.
  12. HP Compaq C700 Touchpad Replacement: passo 12, immagine 1 di 1
    • Gently pull out the three wires.
  13. HP Compaq C700 Touchpad Replacement: passo 13, immagine 1 di 2 HP Compaq C700 Touchpad Replacement: passo 13, immagine 2 di 2
    • Locate the four 3 mm Phillips head screws.
  14. HP Compaq C700 Touchpad Replacement: passo 14, immagine 1 di 1
    • Unhook the display connector wire.
  15. HP Compaq C700 Touchpad Replacement: passo 15, immagine 1 di 1
    • Gently disconnect the display by pulling it upwards.
  16. HP Compaq C700 Touchpad Replacement: passo 16, immagine 1 di 1
    • Locate the disk drive on the side of the device.
    • Remove it by pulling it all the way out.
  17. HP Compaq C700 Touchpad Replacement: passo 17, immagine 1 di 1
    • Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
  18. HP Compaq C700 Touchpad Replacement: passo 18, immagine 1 di 1
    • Disconnect the touchpad connection using the tweezers.
  19. HP Compaq C700 Touchpad Replacement: passo 19, immagine 1 di 1
    • Use the plastic opening tool to pry up all sides of the device cover.
  20. HP Compaq C700 Touchpad Replacement: passo 20, immagine 1 di 1
    • Remove the cover by lifting it.
  21. HP Compaq C700 Touchpad Replacement: passo 21, immagine 1 di 1
    • Use the PH0 screwdriver to remove the six 1 mm Phillips head screws surrounding the touchpad
  22. HP Compaq C700 Touchpad Replacement: passo 22, immagine 1 di 1
    • Use the tweezers to remove the touchpad wire connection.
  23. HP Compaq C700 Touchpad Replacement: passo 23, immagine 1 di 2 HP Compaq C700 Touchpad Replacement: passo 23, immagine 2 di 2
    • Use the plastic opening tool to pry up the touchpad cover.
    • Lift and remove the touchpad cover.
  24. HP Compaq C700 Touchpad Replacement: passo 24, immagine 1 di 1
    • Use the blow dryer to melt the adhesive around the edge of the touchpad.
    • The touchpad is now free to be removed.
    Please add the last step of fixing a new touchpad with glue (what type of glue, how much is to be applied and the like.
    Thanks
    ksivasankaram - Replica
Conclusione
UMass Dartmouth, Team 5-6, Martin Fall 2016 Membro di UMass Dartmouth, Team 5-6, Martin Fall 2016
UMASSD-MARTIN-F16S5G6
3 Membri
6 Guide realizzate
1Commento della guida
I need Compaq laptop c700 Touch pad
So how can I get it?
Suraj Verma - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,422
