HP Compaq 6710b Heat Sink Replacement
Introduzione
Vai al passo 1You will need to take out the keyboard as a part of replacing the heat sink. Know the steps to Keyboard Replacement before starting on this.
Cosa ti serve
Strumenti
Mostra di più…
Flip the laptop over to the back.
Using two hands, push on the tabs while gently taking out the battery.
Flip to the backside of the laptop.
Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
Using the same screwdriver, unscrew the 8mm screws.
Using two fingers, open the prongs holding the RAM
Then slide the RAM out from the socket
Altre 9 persone hanno completato questa guida.
3 Commenti
That was easy. Thanks man :)
Piece of cake ! Thanks. :)
