Salta al contenuto principale
Graco Secure Coverage Parent Unit Battery Replacement
Rogelio Morales
Rogelio Morales e 6 altri collaboratori
Ultimo aggiornamento il January 5, 2024
Nessuna stima
Moderato
Introduzione Migliore
Introduzione
Vai al passo 1
Use this guide to replace the battrey on your Graco Secure Coverage Digital Baby Monitor for the parent unit.
The battery replacement includes the battery replacement.
Cosa ti serve
Strumenti
  1. Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: passo 1, immagine 1 di 3 Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: passo 1, immagine 2 di 3 Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: passo 1, immagine 3 di 3
    • Using plastic opening tool, pry and remove the battery lid.
  2. Graco Secure Coverage Parent Unit Battery Replacement: passo 2, immagine 1 di 1
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
Conclusione
Rogelio Morales
Membro da: 08/31/15
201 Reputazione
2 Guide realizzate
USF Tampa, Team 6-5, Remmell Fall 2015 Membro di USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
4 Membri
8 Guide realizzate
Un commento
Would anyone happen to know the type of battery needed for the replacement on this baby monitor?
Shaun Barnes (WheelchairShaun) - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 778
