Salta al contenuto principale
Graco Secure Coverage LED Parent Unit Replacement
Bryson Wolff
Bryson Wolff e 2 altri collaboratori
Ultimo aggiornamento il December 7, 2015
Nessuna stima
Moderato
Inconveniente Markup
Introduzione
Vai al passo 1
Use this guide to replace the LED on your Graco Secure Coverage Digital Baby Monitor for parent unit.
The LED replacement includes the LED and battery replacement.
Cosa ti serve
Strumenti
Mostra di più…
  1. Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: passo 1, immagine 1 di 3 Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: passo 1, immagine 2 di 3 Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: passo 1, immagine 3 di 3
    • Using plastic opening tool, pry and remove the battery lid.
  2. Graco Secure Coverage LED Parent Unit Replacement: passo 2, immagine 1 di 1
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
  3. Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: passo 3, immagine 1 di 2 Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: passo 3, immagine 2 di 2
    • There are two screws on the rare case of the device. For the one shown in blue marker requires either an extended screwdriver or putting on a little pressure on a regular screwdriver.
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • If you cannot remove the screw with low pressure, do not use high pressure to remove it. It may cause a damage on the device case. Use an extended screwdriver instead.
  4. Graco Secure Coverage LED Parent Unit Replacement: passo 4, immagine 1 di 2 Graco Secure Coverage LED Parent Unit Replacement: passo 4, immagine 2 di 2
    • Using opening plastic tool, pry the two grey cases from both sides of the device.
    • Take your time and apply constant force to avoid breaking or damaging any other plastic parts.
    • While pry off the grey cases, hold the device with your other hand to remove the cases
  5. Graco Secure Coverage LED Parent Unit Replacement: passo 5, immagine 1 di 1
    • Pry the edges of the device to separate the front and rare cases.
    • While prying the edges, hold the device with one hand to pull out each case a part.
    • Make sure you use a constant force, and the pushbuttons are pried off completely.
  6. Graco Secure Coverage LED Parent Unit Replacement: passo 6, immagine 1 di 2 Graco Secure Coverage LED Parent Unit Replacement: passo 6, immagine 2 di 2
    • Remove the 7mm Phillips #1 screw from the mother board.
    • Place the screw in a secure place.
  7. Graco Secure Coverage LED Parent Unit Replacement: passo 7, immagine 1 di 2 Graco Secure Coverage LED Parent Unit Replacement: passo 7, immagine 2 di 2
    • Flip over the motherboard.
    • Solder off LED from motherboard.
    • There are many pins attached to the motherboard, make sure you solder off the proper pins that attached to the LED's.
    • Replace the LED's
Conclusione
Bryson Wolff
Membro da: 08/31/15
237 Reputazione
2 Guide realizzate
USF Tampa, Team 6-5, Remmell Fall 2015 Membro di USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
4 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 124
