Salta al contenuto principale
Google Pixelbook Left Charging Port Replacement
Alon Gary
Alon Gary e 3 altri collaboratori
Ultimo aggiornamento il May 7, 2024
5 - 20 minuti
Moderato
Introduzione
Vai al passo 1
In this guide, you will learn how to replace the left charging port on your Google Pixelbook to fix charging issues.
Cosa ti serve
Strumenti
Mostra di più…
  1. Google Pixelbook Left Charging Port Replacement, Battery (Back Panel): passo 1, immagine 1 di 3 Google Pixelbook Left Charging Port Replacement, Battery (Back Panel): passo 1, immagine 2 di 3 Google Pixelbook Left Charging Port Replacement, Battery (Back Panel): passo 1, immagine 3 di 3
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
    After using the spurger to start lifting the rubber like cover at a corner, a two inch wide paint scrapper proved to be an easy way to continue. Using the scrapper at roughly a 30 degree angle (with respect to the laptop rectangle) allowed progressive lifting of the cover. Ripping of the cover tended to occur if only the narrow spurger was used.
    Marvin Stodolsky - Replica
    Please i need to buy the motherboard
    This my email chikaubah33@yahoo.com
    chika ubah - Replica
    The narrow rubber foot at the base of the display is supported by bendable metal. Be careful how evenly you remove it as uneven motions will result in a more bent and harder to re-apply piece.
    Meta Data - Replica
  2. Google Pixelbook Left Charging Port Replacement: passo 2, immagine 1 di 2 Google Pixelbook Left Charging Port Replacement: passo 2, immagine 2 di 2
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Google Pixelbook Left Charging Port Replacement: passo 3, immagine 1 di 3 Google Pixelbook Left Charging Port Replacement: passo 3, immagine 2 di 3 Google Pixelbook Left Charging Port Replacement: passo 3, immagine 3 di 3
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
    Just a heads up on “Step 3”: (not sure if maybe mine is a newer model since I just got it about a week ago) But there are only 15 of the T5 Screws on mine… Not 17. There are only 2, instead of 4, screws at the top of the picture (located at the hinge) showing the back where they are all circled.
    Jeff Lewis - Replica
    I had the same experience as Jeff.
    Paul Schreiber - Replica
    same, there are only two screws up top, not 4, thus 15 total
    Meta Data - Replica
  4. Google Pixelbook Left Charging Port Replacement: passo 4, immagine 1 di 3 Google Pixelbook Left Charging Port Replacement: passo 4, immagine 2 di 3 Google Pixelbook Left Charging Port Replacement: passo 4, immagine 3 di 3
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Google Pixelbook Left Charging Port Replacement: passo 5, immagine 1 di 2 Google Pixelbook Left Charging Port Replacement: passo 5, immagine 2 di 2
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
    For me, these were T4 and not T3 screws (everything labelled T3 was a T4 for me).
  6. Google Pixelbook Left Charging Port Replacement: passo 6, immagine 1 di 2 Google Pixelbook Left Charging Port Replacement: passo 6, immagine 2 di 2
    • Remove the small, black casing by using the spudger to lift it up from its place.
    Does anyone know if I can get the cable shown in this image as its own part? It is the only thing wrong with my machine and I don't want to fork out £70 for an entire new battery and cable.
    Mark Huttley - Replica
  7. Google Pixelbook Left Charging Port Replacement: passo 7, immagine 1 di 1
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
  8. Google Pixelbook Left Charging Port Replacement, Left Charging Port: passo 8, immagine 1 di 2 Google Pixelbook Left Charging Port Replacement, Left Charging Port: passo 8, immagine 2 di 2
    • Remove the two 3.0mm silver screws from the thin, black component by using a T3 Torx screwdriver to turn the screws counterclockwise.
  9. Google Pixelbook Left Charging Port Replacement: passo 9, immagine 1 di 2 Google Pixelbook Left Charging Port Replacement: passo 9, immagine 2 di 2
    • Disconnect the thin, black and white cord from the motherboard by using the spudger to snap the connector up and out of place.
  10. Google Pixelbook Left Charging Port Replacement: passo 10, immagine 1 di 1
    • Remove the thin, black component by pulling it up and out of the laptop with your fingers.
    • This photo shows the bottom screw still in the black box, but yours should be removed.
  11. Google Pixelbook Left Charging Port Replacement: passo 11, immagine 1 di 1
    • Remove the gold 2.0mm corner screw by turning it counterclockwise with a T3 Torx screwdriver.
  12. Google Pixelbook Left Charging Port Replacement: passo 12, immagine 1 di 2 Google Pixelbook Left Charging Port Replacement: passo 12, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Using needle-nose tweezers, remove the silver casing by lifting it up and out of the computer.
  13. Google Pixelbook Left Charging Port Replacement: passo 13, immagine 1 di 2 Google Pixelbook Left Charging Port Replacement: passo 13, immagine 2 di 2
    • Remove the three 3.0mm black screws on the right side by using a T5 Torx screwdriver to turn the screws counterclockwise.
    • Remove the silver 2.0mm screw on the left side by using a T3 Torx screwdriver to turn the screw counterclockwise.
  14. Google Pixelbook Left Charging Port Replacement: passo 14, immagine 1 di 1
    • Disconnect the thin, black ribbon cable by using the spudger to lift it up from the computer.
  15. Google Pixelbook Left Charging Port Replacement: passo 15, immagine 1 di 2 Google Pixelbook Left Charging Port Replacement: passo 15, immagine 2 di 2
    • Use the needle-nose tweezers to remove the charging port by lifting the component up and out of the Pixelbook.
Conclusione
Alon Gary
Membro da: 01/24/18
576 Reputazione
2 Guide realizzate
Cal Poly, Team S18-G1, Livingston Winter 2018 Membro di Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
4 Membri
9 Guide realizzate
3Commenti sulla guida
Where to get replacemt charging port from please
kamil Szym - Replica
Where can we get a replacement charging port for the Pixelbook Go 2 (i7)?
michaelnic - Replica
Hi Michael, did you manage to find the charging port and replace it for the Pixelbook Go?
redshift galaxy -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 25
Tutti i Tempi: 3,201
