Salta al contenuto principale
Google Pixel C Power Button Replacement
Isabelle Tang
Isabelle Tang e 3 altri collaboratori
Ultimo aggiornamento il 7 mag 2024
25 - 30 minuti
Moderato
Introduzione
Vai al passo 1
This guide will outline how to replace the power button should it be non responsive or faulty.
Cosa ti serve
Strumenti
Mostra di più…
  1. Google Pixel C Power Button Replacement, Screen: passo 1, immagine 1 di 1
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
  2. Google Pixel C Power Button Replacement: passo 2, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 2, immagine 2 di 2
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
    Be very careful at the bottom of the screen, as you can easily tear some screen internal flex cables. If those cables are torn you have to replace the screen
    Hannes - Replica
  3. Google Pixel C Power Button Replacement: passo 3, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 3, immagine 2 di 2
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
    Hi friend I have a tab pixel c like that
    But screen touch is broken
    Where can I find it ? I'm from Tanzania
    Help me please
    Gmail ikbfils@gmail.com
    Ikb Fils - Replica
  4. Google Pixel C Power Button Replacement: passo 4, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
    This is not very useful if there is no way of getting the parts.
    Lorenzo Braschi - Replica
    Hi i seem to have a loose item in my pixel c causing the backlight to not light up, when it doesn’t i can bang on the device and it will come on.
    my question is if i am able to remove the screen in one piece what type of adhesive do i need to re-glue it also leaving it able to be re heated to be removed in the future if need be
    wambobby - Replica
  5. Google Pixel C Power Button Replacement, Power Button: passo 5, immagine 1 di 1
    • Locate the power button along the edge of the tablet.
    • The actual power button technology is the black plastic piece located directly inside the device behind the silver button; this is what will be replaced.
  6. Google Pixel C Power Button Replacement: passo 6, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 6, immagine 2 di 2
    • Locate and remove the black 4.3mm Phillips #000 screw.
    • Remove the remaining two silver 4.2mm Phillips #000 screws.
  7. Google Pixel C Power Button Replacement: passo 7, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 7, immagine 2 di 2
    • Use tweezers to slowly pull up on the power button technology as far as possible without pulling out the two black wires attached.
    • Don't pull up too hard, as the wires could be ripped out and damaged.
  8. Google Pixel C Power Button Replacement: passo 8, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 8, immagine 2 di 2
    • Detach the larger connector wire by flipping the copper hinge located at the base of the connection with your fingernail.
  9. Google Pixel C Power Button Replacement: passo 9, immagine 1 di 1
    • Flip the hinge of the second, more narrow wire to release the connection.
    • Don't pull the power button technology out yet. This wire is attached at one more place in the device.
  10. Google Pixel C Power Button Replacement: passo 10, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 10, immagine 2 di 2
    • Locate and remove the three 4.2mm Phillips #000 screws at the base of where the second wire is still connected.
  11. Google Pixel C Power Button Replacement: passo 11, immagine 1 di 2 Google Pixel C Power Button Replacement: passo 11, immagine 2 di 2
    • Once all the screws are removed, gently pull up on the entire power button technology piece, to remove it from the device.
Conclusione
To reassemble your device, follow these instructions in reverse order. New adhesive will be needed to re-apply the screen.
Isabelle Tang
Membro da: 04/26/17
225 Reputazione
2 Guide realizzate
Cal Poly, Team S21-G4, Livingston Spring 2017 Membro di Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 Membri
11 Guide realizzate
1Commento della guida
I have replaced the power/volume button flex with these instructions with a reportably working item, but power button still doesn't work. The volume buttons work just fine. Any other ideas about what might be the problem?
Colleen Price - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 31
Tutti i Tempi: 2,517
