Salta al contenuto principale
Google Pixel 9 Pro Rear Cover Replacement
Cosa ti serve
  1. Google Pixel 9 Pro Rear Cover Replacement, Safety precautions: passo 1, immagine 1 di 2 Google Pixel 9 Pro Rear Cover Replacement, Safety precautions: passo 1, immagine 2 di 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel 9 Pro Rear Cover Replacement, Adhesive information: passo 2, immagine 1 di 3 Google Pixel 9 Pro Rear Cover Replacement, Adhesive information: passo 2, immagine 2 di 3 Google Pixel 9 Pro Rear Cover Replacement, Adhesive information: passo 2, immagine 3 di 3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel 9 Pro Rear Cover Replacement, Apply a suction handle: passo 3, immagine 1 di 2 Google Pixel 9 Pro Rear Cover Replacement, Apply a suction handle: passo 3, immagine 2 di 2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel 9 Pro Rear Cover Replacement, Insert an opening pick: passo 4, immagine 1 di 3 Google Pixel 9 Pro Rear Cover Replacement, Insert an opening pick: passo 4, immagine 2 di 3 Google Pixel 9 Pro Rear Cover Replacement, Insert an opening pick: passo 4, immagine 3 di 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel 9 Pro Rear Cover Replacement, Separate the rear cover adhesive: passo 5, immagine 1 di 3 Google Pixel 9 Pro Rear Cover Replacement, Separate the rear cover adhesive: passo 5, immagine 2 di 3 Google Pixel 9 Pro Rear Cover Replacement, Separate the rear cover adhesive: passo 5, immagine 3 di 3
    • Slide your opening pick along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel 9 Pro Rear Cover Replacement: passo 6, immagine 1 di 3 Google Pixel 9 Pro Rear Cover Replacement: passo 6, immagine 2 di 3 Google Pixel 9 Pro Rear Cover Replacement: passo 6, immagine 3 di 3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel 9 Pro Rear Cover Replacement: passo 7, immagine 1 di 3 Google Pixel 9 Pro Rear Cover Replacement: passo 7, immagine 2 di 3 Google Pixel 9 Pro Rear Cover Replacement: passo 7, immagine 3 di 3
    • Slide your pick down the right edge to separate the remaining adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel 9 Pro Rear Cover Replacement, Prop up the rear cover: passo 8, immagine 1 di 3 Google Pixel 9 Pro Rear Cover Replacement, Prop up the rear cover: passo 8, immagine 2 di 3 Google Pixel 9 Pro Rear Cover Replacement, Prop up the rear cover: passo 8, immagine 3 di 3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel 9 Pro Rear Cover Replacement, Remove the wireless charging assembly: passo 9, immagine 1 di 2 Google Pixel 9 Pro Rear Cover Replacement, Remove the wireless charging assembly: passo 9, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    FixMat
    $31.41
    • While the Pixel 9 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the five screws securing the wireless charging assembly:
    • Four 5.4 mm‑long screws
    • One 1.5 mm‑long screw
    • This screw is non‑magnetic—you may need to use tweezers to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel 9 Pro Rear Cover Replacement: passo 10, immagine 1 di 3 Google Pixel 9 Pro Rear Cover Replacement: passo 10, immagine 2 di 3 Google Pixel 9 Pro Rear Cover Replacement: passo 10, immagine 3 di 3
    • Be very careful not to damage the spring contacts under the top left edge of the wireless charging assembly.
    • Use tweezers or your fingers to remove the wireless charging assembly.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel 9 Pro Rear Cover Replacement, Disconnect the rear cover: passo 11, immagine 1 di 3 Google Pixel 9 Pro Rear Cover Replacement, Disconnect the rear cover: passo 11, immagine 2 di 3 Google Pixel 9 Pro Rear Cover Replacement, Disconnect the rear cover: passo 11, immagine 3 di 3
    • Insert the tip of an opening pick under the left edge of the rear cover press connector and pry straight up to disconnect it.
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel 9 Pro Rear Cover Replacement, Remove the rear cover: passo 12, immagine 1 di 1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your rear cover.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Altre 3 persone hanno completato questa guida.
Spencer Day
Membro da: 09/14/22
191.306 Reputazione
1.204 guide realizzate
iFixit Membro di iFixit
Staff
122 Membri
25.947 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 12
Ultimi 7 giorni: 91
Ultimi 30 giorni: 377
Tutti i Tempi: 7,536
