Salta al contenuto principale
Google Pixel 9 Pro Fold Inner Front Camera Replacement
Cosa ti serve
  1. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Prepare your phone for disassembly: passo 1, immagine 1 di 1
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Insert an opening pick: passo 2, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Insert an opening pick: passo 2, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Insert an opening pick: passo 2, immagine 3 di 3
    • Apply a suction cup to the back cover, as close to the center of the bottom edge as possible.
    • While securing the phone with one hand, pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert an opening pick into the gap.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken back cover.
  3. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Separate the back cover adhesive: passo 3, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Separate the back cover adhesive: passo 3, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Separate the back cover adhesive: passo 3, immagine 3 di 3
    • During the next two steps, don't insert your opening pick deeper than 3 mm to prevent damaging the metal springs around the frame.
    • Optionally, you can measure and mark your opening pick at 3 mm to help you visualize the length.
    • Remove the suction handle from the back cover.
    • Slide the opening pick around the bottom left corner and up the left edge of the back cover to separate the adhesive.
  4. Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 4, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 4, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 4, immagine 3 di 3
    • Continue sliding the pick around the top left corner and across the top edge of the back cover.
  5. Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 5, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 5, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 5, immagine 3 di 3
    • The adhesive along the right edge of the back cover is thicker than the rest. You'll need to insert your opening pick at a minimum of 4 mm to separate the adhesive.
    • Slide your pick down the right edge and around the bottom right corner to separate the remaining adhesive.
  6. Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 6, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 6, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 6, immagine 3 di 3
    • Don't fully remove the back cover yet, as it's still connected to the phone by a cable.
    • At this point, the back cover should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the bottom edge of the back cover and swing it over the top edge of the phone.
    • Prop up the back cover with your suction handle or a clean, sturdy object—making sure that the cable isn't strained.
  7. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the top bracket screw: passo 7, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the top bracket screw: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    FixMat
    $36.95
    • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the top bracket.
  8. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the top bracket: passo 8, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the top bracket: passo 8, immagine 2 di 2
    • Use tweezers, or your fingers, to pull the top bracket towards the top of the phone to release it from its clip.
    • Remove the top bracket.
  9. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Disconnect the back cover cable: passo 9, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Disconnect the back cover cable: passo 9, immagine 2 di 2
    • Insert the tip of your spudger under the bottom edge of the back cover cable press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
    • Pry up and disconnect the back cover cable.
  10. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the back cover: passo 10, immagine 1 di 1
    • Lift the back cover off the frame and remove it.
  11. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the base battery bracket screws: passo 11, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the base battery bracket screws: passo 11, immagine 2 di 2
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the base battery bracket.
  12. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the base battery bracket: passo 12, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the base battery bracket: passo 12, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the base battery bracket: passo 12, immagine 3 di 3
    • Use tweezers, or your fingers, to pull the base battery bracket toward the bottom of the phone to release it from its clip.
    • Remove the base battery bracket.
  13. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Disconnect the base battery: passo 13, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Disconnect the base battery: passo 13, immagine 2 di 2
    • Insert the tip of your spudger under the bottom left corner of the base battery press connector, near the gold marker.
    • Pry up and disconnect the base battery.
  14. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the inner front camera bracket screws: passo 14, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the inner front camera bracket screws: passo 14, immagine 2 di 2
    • Use a Torx Plus 3IP driver to remove the two 2.6 mm‑long screws securing the inner front camera bracket.
  15. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the inner front camera bracket: passo 15, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the inner front camera bracket: passo 15, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the inner front camera bracket: passo 15, immagine 3 di 3
    • Use tweezers, or your fingers, to lift the inner front camera bracket up and toward the left edge of the phone to release its clips.
    • Remove the inner front camera bracket.
  16. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Disconnect the inner front camera: passo 16, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Disconnect the inner front camera: passo 16, immagine 2 di 2
    • Use a spudger to pry up and disconnect the inner front camera press connector.
  17. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the inner front camera: passo 17, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the inner front camera: passo 17, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the inner front camera: passo 17, immagine 3 di 3
    • Use the point of a spudger to pry up the inner front camera and separate the adhesive securing it to the frame.
    • Remove the inner front camera.
  18. Google Pixel 9 Pro Fold Inner Front Camera Replacement, End of disassembly: passo 18, immagine 1 di 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
  19. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the old adhesive: passo 19, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the old adhesive: passo 19, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the old adhesive: passo 19, immagine 3 di 3
    • If your inner front camera adhesive isn't sticky or intact anymore, follow the next four steps to replace it. Otherwise, skip the next four steps.
    • Use tweezers, or your fingers, to remove the old adhesive foam from the inner front camera cutout.
    • Use isopropyl alcohol (>90% or greater) and a coffee filter or lint‑free cloth to remove any adhesive residue.
  20. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Apply the new adhesive: passo 20, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Apply the new adhesive: passo 20, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Apply the new adhesive: passo 20, immagine 3 di 3
    • Peel the replacement adhesive foam off its clear liner to expose the adhesive underneath.
    • Align the adhesive foam over the cutout in the frame so that the pull tab is facing the bottom of the phone.
    • Place the adhesive in the cutout.
  21. Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 21, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 21, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 21, immagine 3 di 3
    • Use the tip of a spudger to press along the edges of the adhesive foam to secure it to the frame.
  22. Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 22, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 22, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 22, immagine 3 di 3
    • Use tweezers, or your fingers, to peel off the colored liner and expose the adhesive underneath.
  23. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Reinstall the inner front camera: passo 23, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Reinstall the inner front camera: passo 23, immagine 2 di 2
    • While holding the inner front camera above its cutout, reconnect its press connector.
    • Lay the inner front camera in its cutout and press down to secure it to the adhesive.
  24. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Reinstall the inner front camera bracket: passo 24, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Reinstall the inner front camera bracket: passo 24, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Reinstall the inner front camera bracket: passo 24, immagine 3 di 3
    • Reinsert the inner front camera bracket clip under its slot in the logic board and align the screw holes.
  25. Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 25, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 25, immagine 2 di 2
    • Use a Torx Plus 3IP driver to install the two 2.6 mm‑long screws securing the inner front camera bracket.
  26. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Reconnect the base battery: passo 26, immagine 1 di 1
    • Reconnect the base battery press connector.
  27. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Reinstall the base battery bracket: passo 27, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Reinstall the base battery bracket: passo 27, immagine 2 di 2
    • Reinsert the base battery bracket clip under its slot in the logic board and align its screw holes.
  28. Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 28, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 28, immagine 2 di 2
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the base battery bracket.
  29. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the old adhesive: passo 29, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the old adhesive: passo 29, immagine 2 di 2
    • Use a spudger, or your fingers, to remove the old back cover adhesive.
    • Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
  30. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the back cover liners: passo 30, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the back cover liners: passo 30, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the back cover liners: passo 30, immagine 3 di 3
    • If you're replacing your back cover with a new one, follow the next two steps. Otherwise, skip them.
    • Use tweezers, or your fingers, to remove the three rear camera liners from the inside of your new back cover.
  31. Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 31, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 31, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 31, immagine 3 di 3
    • Peel off the remaining clear liners on the outside of the back cover.
  32. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Compare your adhesive: passo 32, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Compare your adhesive: passo 32, immagine 2 di 2
    • Before removing any liners, check if the adhesive matches the frame.
    • The clear liner should face the frame.
  33. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Apply the new adhesive: passo 33, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Apply the new adhesive: passo 33, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Apply the new adhesive: passo 33, immagine 3 di 3
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel away the top half of the new adhesive strip from its clear liner and keep it folded before continuing.
    • Align the top half of the adhesive over the frame, using the corners as reference points.
    • Place the adhesive on the frame.
  34. Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 34, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 34, immagine 2 di 2
    • Use the flat end of a spudger, or your fingers, to press down the top edge of the adhesive and adhere it to the frame.
  35. Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 35, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 35, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 35, immagine 3 di 3
    • While peeling away the rest of the clear liner, slowly lay the rest of the adhesive over the perimeter of the phone.
  36. Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 36, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 36, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 36, immagine 3 di 3
    • Use the flat end of a spudger, or your fingers, to press down the rest of the adhesive and adhere it to the frame.
  37. Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 37, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 37, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 37, immagine 3 di 3
    • Use a spudger to pry up the segmented tab on the bottom right corner of the large blue liner.
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
  38. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Reconnect the back cover cable: passo 38, immagine 1 di 1
    • While holding the back cover or propping it up, reconnect the back cover cable.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  39. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Reinstall the top bracket: passo 39, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Reinstall the top bracket: passo 39, immagine 2 di 2
    • Reinsert the top bracket clip under its slot in the logic board and align its screw hole.
  40. Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 40, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 40, immagine 2 di 2
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the top bracket.
  41. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the secondary liner: passo 41, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Remove the secondary liner: passo 41, immagine 2 di 2
    • Use the tip of a spudger to pry up the segmented tab on the top right corner of the secondary liner.
  42. Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 42, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 42, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 42, immagine 3 di 3
    • Peel off the secondary liner to expose the adhesive.
  43. Google Pixel 9 Pro Fold Inner Front Camera Replacement, Secure the back cover: passo 43, immagine 1 di 2 Google Pixel 9 Pro Fold Inner Front Camera Replacement, Secure the back cover: passo 43, immagine 2 di 2
    • Align the top edge of the back cover with the frame and press down to adhere it.
  44. Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 44, immagine 1 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 44, immagine 2 di 3 Google Pixel 9 Pro Fold Inner Front Camera Replacement: passo 44, immagine 3 di 3
    • Press along the perimeter of the back cover to adhere it to the frame.
    • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
    • Let the phone sit a few hours for the adhesive to cure.
Conclusione
Congratulations on completing your repair!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 9 Pro Fold Answers Community for help.
Alex Diaz-Kokaisl
Membro da: 01/16/22
235.638 Reputazione
1.142 Guide realizzate
iFixit Membro di iFixit
Staff
125 Membri
25.389 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 31
Tutti i Tempi: 416
