Salta al contenuto principale
Google Pixel 9 5G mmWave Antenna Replacement
Cosa ti serve
  1. Google Pixel 9 5G mmWave Antenna Replacement, Prepare your Pixel for disassembly: passo 1, immagine 1 di 3 Google Pixel 9 5G mmWave Antenna Replacement, Prepare your Pixel for disassembly: passo 1, immagine 2 di 3 Google Pixel 9 5G mmWave Antenna Replacement, Prepare your Pixel for disassembly: passo 1, immagine 3 di 3
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Google Pixel 9 5G mmWave Antenna Replacement, Adhesive information: passo 2, immagine 1 di 3 Google Pixel 9 5G mmWave Antenna Replacement, Adhesive information: passo 2, immagine 2 di 3 Google Pixel 9 5G mmWave Antenna Replacement, Adhesive information: passo 2, immagine 3 di 3
    • Adhesive secures the perimeter of the back glass to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the back glass to avoid damaging the internal components.
    • To help, measure and mark 3 mm from the tip of an opening pick with a permanent marker.
    • If your screen or back glass is badly cracked, a suction cup may not perfectly adhere.
    • Lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier. Ensure there's a smooth area near the bottom edge that's large and smooth enough for a suction cup to stick to.
  3. Google Pixel 9 5G mmWave Antenna Replacement, Apply a suction handle: passo 3, immagine 1 di 2 Google Pixel 9 5G mmWave Antenna Replacement, Apply a suction handle: passo 3, immagine 2 di 2
    • Place a suction handle at the bottom edge of the back glass, as close to the edge as possible.
    • Push down to attach the suction cup.
  4. Google Pixel 9 5G mmWave Antenna Replacement, Insert an opening pick: passo 4, immagine 1 di 3 Google Pixel 9 5G mmWave Antenna Replacement, Insert an opening pick: passo 4, immagine 2 di 3 Google Pixel 9 5G mmWave Antenna Replacement, Insert an opening pick: passo 4, immagine 3 di 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the back glass.
    • Insert the tip of an opening pick into the gap.
  5. Google Pixel 9 5G mmWave Antenna Replacement, Separate the back glass adhesive: passo 5, immagine 1 di 3 Google Pixel 9 5G mmWave Antenna Replacement, Separate the back glass adhesive: passo 5, immagine 2 di 3 Google Pixel 9 5G mmWave Antenna Replacement, Separate the back glass adhesive: passo 5, immagine 3 di 3
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 5G mmWave Antenna Replacement: passo 6, immagine 1 di 3 Google Pixel 9 5G mmWave Antenna Replacement: passo 6, immagine 2 di 3 Google Pixel 9 5G mmWave Antenna Replacement: passo 6, immagine 3 di 3
    • Slide the opening pick around the perimeter of the phone, slicing the rest of the adhesive.
  7. Google Pixel 9 5G mmWave Antenna Replacement: passo 7, immagine 1 di 3 Google Pixel 9 5G mmWave Antenna Replacement: passo 7, immagine 2 di 3 Google Pixel 9 5G mmWave Antenna Replacement: passo 7, immagine 3 di 3
    • With most of the adhesive separated, lightly twist the opening pick at the bottom edge to lift the back glass up until you can grip it with your fingers.
    • Use the opening pick to separate any remaining sections of adhesive securing the back glass.
  8. Google Pixel 9 5G mmWave Antenna Replacement, Remove the back glass: passo 8, immagine 1 di 1
    • Remove the back glass.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back glass.
  9. Google Pixel 9 5G mmWave Antenna Replacement, Remove the upper board cover: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    FixMat
    $31.41
    • While the Pixel 9 uses Torx Plus screws, standard Torx bits also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the single 5.4 mm‑long screw securing the upper board cover.
  10. Google Pixel 9 5G mmWave Antenna Replacement: passo 10, immagine 1 di 2 Google Pixel 9 5G mmWave Antenna Replacement: passo 10, immagine 2 di 2
    • Use a pair of tweezers to remove the upper board cover.
  11. Google Pixel 9 5G mmWave Antenna Replacement, Remove the midframe: passo 11, immagine 1 di 1
    • Use a 3IP Torx driver to remove the five screws securing the midframe and wireless charging coil:
    • Four 5.4 mm-long screws
    • One 2.2 mm-long screw
  12. Google Pixel 9 5G mmWave Antenna Replacement, Peel up the flash cable: passo 12, immagine 1 di 2 Google Pixel 9 5G mmWave Antenna Replacement, Peel up the flash cable: passo 12, immagine 2 di 2
    • Use a pair of tweezers to peel the flash cable off of the metal midframe.
  13. Google Pixel 9 5G mmWave Antenna Replacement, Remove the midframe: passo 13, immagine 1 di 2 Google Pixel 9 5G mmWave Antenna Replacement, Remove the midframe: passo 13, immagine 2 di 2
    • Remove the midframe, wireless charging coil, and NFC assembly.
  14. Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the battery: passo 14, immagine 1 di 2 Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the battery: passo 14, immagine 2 di 2
    • Use the tip of a spudger to pry up and disconnect the battery connector.
  15. Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: passo 15, immagine 1 di 3 Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: passo 15, immagine 2 di 3 Google Pixel 9 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: passo 15, immagine 3 di 3
    • Use the tip of a spudger to pry up and disconnect the 5G mmWave antenna's press connector.
  16. Google Pixel 9 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna: passo 16, immagine 1 di 3 Google Pixel 9 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna: passo 16, immagine 2 di 3 Google Pixel 9 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna: passo 16, immagine 3 di 3
    • Remove the 5G mmWave antenna.
    • A small flex cable attaches to the back of the antenna with a press connector. You may need to reconnect it if it falls off.
    • During reassembly, insert the antenna so it's between the frame and the small metal bracket near the top right corner.
Conclusione
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 9 Answers Community for help.
Carsten Frauenheim
Membro da: 03/10/20
155.320 Reputazione
439 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.608 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 164
Tutti i Tempi: 2,499
