Salta al contenuto principale
Golf Club Grip Replacement
Skylar Nichols
Skylar Nichols e 5 altri collaboratori
Ultimo aggiornamento il August 7, 2023
10 minuti
Facile
Guida Studente in Evidenza
Introduzione
Vai al passo 1
For this Fast Fixit you will be taking off a worn or old golf grip and replacing it with a new one. In order to do this we will be cutting the old grip off and putting an adhesive solution along with tape onto the golf club in order to attach the new grip.
  1. Golf Club Grip Replacement, Grip: passo 1, immagine 1 di 2 Golf Club Grip Replacement, Grip: passo 1, immagine 2 di 2
    • Place the golf club securely on a level table.
    • Using a blade or knife, cut a line through the grip.
  2. Golf Club Grip Replacement: passo 2, immagine 1 di 3 Golf Club Grip Replacement: passo 2, immagine 2 di 3 Golf Club Grip Replacement: passo 2, immagine 3 di 3
    • Remove the grip from the golf club shaft.
  3. Golf Club Grip Replacement: passo 3, immagine 1 di 1
    • Use the knife to take off any excess residue from the shaft of the club.
  4. Golf Club Grip Replacement: passo 4, immagine 1 di 2 Golf Club Grip Replacement: passo 4, immagine 2 di 2
    • Apply the double sided tape to the bare shaft in a spiral pattern.
    • Use the grip to determine how far up the shaft the tape needs to go.
  5. Golf Club Grip Replacement: passo 5, immagine 1 di 1
    • Remove the tape backing.
  6. Golf Club Grip Replacement: passo 6, immagine 1 di 3 Golf Club Grip Replacement: passo 6, immagine 2 di 3 Golf Club Grip Replacement: passo 6, immagine 3 di 3
    • Place a golf tee in the hole at the end of the golf grip.
  7. Golf Club Grip Replacement: passo 7, immagine 1 di 2 Golf Club Grip Replacement: passo 7, immagine 2 di 2
    • Pour a generous amount of adhesive into the opposite end of the grip.
    • Squeeze together the open end of the grip.
    • Lightly shake, in order to spread the adhesive within the grip.
  8. Golf Club Grip Replacement: passo 8, immagine 1 di 1
    • Over a bowl or container, pour adhesive in the grip onto the shaft of the golf club.
  9. Golf Club Grip Replacement: passo 9, immagine 1 di 2 Golf Club Grip Replacement: passo 9, immagine 2 di 2
    • Remove the tee from the back of the grip.
    • Push the grip onto the golf club shaft.
    • Ensure that the end of the grip is hitting the end of the shaft.
  10. Golf Club Grip Replacement: passo 10, immagine 1 di 1
    • Allow to dry at least 12 hours before use.
Conclusione
After allowing the club to properly dry, you will have a new grip to improve your swing at tee off.
Altre 6 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 45
Tutti i Tempi: 7,360
