Salta al contenuto principale
GoPro Hero3+ Silver Edition Front Panel Replacement
Patrick Cook
Patrick Cook e 6 altri collaboratori
Ultimo aggiornamento il 31 mag 2021
2 minuti
Molto facile
Introduzione
Vai al passo 1
Oops! You scratched the front of your GoPro and you don't want others to question if you take care of your camera. Let's replace that face plate and make it look good as new!
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. GoPro Hero3+ Silver Edition Front Panel Replacement, Front Panel: passo 1, immagine 1 di 1
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  2. GoPro Hero3+ Silver Edition Front Panel Replacement: passo 2, immagine 1 di 1
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 5-8, Maness Fall 2015 Membro di Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 643
