Salta al contenuto principale
GoPro Hero LCD Screen Replacement
River Drake
River Drake e 4 altri collaboratori
Ultimo aggiornamento il 26 mag 2021
15 - 20 minuti
Moderato
Foto Azione
Introduzione
Vai al passo 1
If for some reason, your screen is dysfunctional, you can replace it. Since it is near the bottom of the camera, it is not easy to replace. Grab your screwdrivers and tweezers and let's go!
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. GoPro Hero LCD Screen Replacement, Casing: passo 1, immagine 1 di 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero LCD Screen Replacement: passo 2, immagine 1 di 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero LCD Screen Replacement: passo 3, immagine 1 di 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero LCD Screen Replacement: passo 4, immagine 1 di 1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero LCD Screen Replacement: passo 5, immagine 1 di 1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero LCD Screen Replacement: passo 6, immagine 1 di 1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero LCD Screen Replacement, LCD Screen: passo 7, immagine 1 di 2 GoPro Hero LCD Screen Replacement, LCD Screen: passo 7, immagine 2 di 2
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
    gostaria de compra essa parte completa
    nishiura447 - Replica
  8. GoPro Hero LCD Screen Replacement: passo 8, immagine 1 di 1
    • Separate the motherboard from the white piece of plastic.
  9. GoPro Hero LCD Screen Replacement: passo 9, immagine 1 di 1
    • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
  10. GoPro Hero LCD Screen Replacement: passo 10, immagine 1 di 2 GoPro Hero LCD Screen Replacement: passo 10, immagine 2 di 2
    • Separate the LCD screen from the motherboard.
Conclusione
Altre 5 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
River Drake
Membro da: 04/02/15
1.047 Reputazione
5 Guide realizzate
Cal Poly, Team 12-2, Lancaster Spring 2015 Membro di Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Membri
18 Guide realizzate
3Commenti sulla guida
Where do you buy the replacement lcd
Anthony Volatile - Replica
Gopro hero 7 white repair cost:
Screen: $45 - https://www.ebay.com.au/itm/183828969944
Side panel: $35 - https://www.herogear.com.au/genuine-repl...
Addisen KING -
I can find the screen but is it compatible with the Hero+
Brian Casado - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 138
Tutti i Tempi: 25,530
