Salta al contenuto principale
GoPro Hero+ LCD Lens Replacement
Matthew Tinkey
Matthew Tinkey e 4 altri collaboratori
Ultimo aggiornamento il 28 mag 2021
5 - 10 minuti
Difficile
Introduzione
Vai al passo 1
To remove the lens assembly, you must remove some internal parts first. Some of these screws are in tight places, so they will be tedious to access.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. GoPro Hero+ LCD Lens Replacement, Back Panel: passo 1, immagine 1 di 2 GoPro Hero+ LCD Lens Replacement, Back Panel: passo 1, immagine 2 di 2
    • Be sure to power off the GoPro before you start disassembly.
    • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
    No parts required! What about the microSD/Micro USB assembly!!!! where to buy?!?!
    WPN - Replica
  2. GoPro Hero+ LCD Lens Replacement: passo 2, immagine 1 di 2 GoPro Hero+ LCD Lens Replacement: passo 2, immagine 2 di 2
    • Use the metal spudger to pry around the perimeter of the panel.
    • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
  3. GoPro Hero+ LCD Lens Replacement: passo 3, immagine 1 di 2 GoPro Hero+ LCD Lens Replacement: passo 3, immagine 2 di 2
    • Pry around the panel to ensure it is not attached to the device.
    • Move the panel to the side so you can access the internal components.
    • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
    а где можно купить вот этот шлейф соединяющий дисплей и плату.???
    Александр «ivkadre» Карпенко - Replica
  4. GoPro Hero+ LCD Lens Replacement, Battery: passo 4, immagine 1 di 1
    • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
    • Be careful of metal contacts on strip; they can be sharp.
  5. GoPro Hero+ LCD Lens Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, peel off the copper tape on the right side of the battery.
  6. GoPro Hero+ LCD Lens Replacement: passo 6, immagine 1 di 2 GoPro Hero+ LCD Lens Replacement: passo 6, immagine 2 di 2
    • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
  7. GoPro Hero+ LCD Lens Replacement: passo 7, immagine 1 di 1
    • Use a pair of tweezers to disconnect the battery connector from the motherboard.
    • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
    Lift the battery connector straight up.
    glenn tanner - Replica
    hi what kind battery can replace for hero+?
    sherwin_0011 - Replica
  8. GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: passo 8, immagine 1 di 3 GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: passo 8, immagine 2 di 3 GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: passo 8, immagine 3 di 3
    • Remove the two 6 mm Phillips #00 screws.
    • Remove the single 4 mm Phillips #000 screws.
  9. GoPro Hero+ LCD Lens Replacement: passo 9, immagine 1 di 1
    • Remove the image sensor from the camera.
    • You do not have to unplug the black box to remove the USB/SD chip.
  10. GoPro Hero+ LCD Lens Replacement: passo 10, immagine 1 di 1
    • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
    • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
  11. GoPro Hero+ LCD Lens Replacement: passo 11, immagine 1 di 1
    • Gently lift the microSD/Micro USB assembly up and out of the device.
  12. GoPro Hero+ LCD Lens Replacement, Image Sensor: passo 12, immagine 1 di 1
    • Use your fingers and gently pull out the sensor from the motherboard by slowly and gradually pulling up on the image sensor box.
    • Do not yank on the image sensor, it can rip out the wiring or damage the motherboard.
  13. GoPro Hero+ LCD Lens Replacement, Motherboard: passo 13, immagine 1 di 3 GoPro Hero+ LCD Lens Replacement, Motherboard: passo 13, immagine 2 di 3 GoPro Hero+ LCD Lens Replacement, Motherboard: passo 13, immagine 3 di 3
    • Remove the three 4 mm Phillips #000 screws securing the motherboard.
  14. GoPro Hero+ LCD Lens Replacement: passo 14, immagine 1 di 1
    • Use your fingers to gently remove the ribbon connected to the lens.
    • Be careful when removing the ribbon cable. Pull off gently or you can separate the ribbon from the contacts.
  15. GoPro Hero+ LCD Lens Replacement: passo 15, immagine 1 di 3 GoPro Hero+ LCD Lens Replacement: passo 15, immagine 2 di 3 GoPro Hero+ LCD Lens Replacement: passo 15, immagine 3 di 3
    • Use your fingers and carefully pull out the motherboard from under the lens. It may take a little bit of adjusting to get it out.
  16. GoPro Hero+ LCD Lens Replacement, Lens: passo 16, immagine 1 di 3 GoPro Hero+ LCD Lens Replacement, Lens: passo 16, immagine 2 di 3 GoPro Hero+ LCD Lens Replacement, Lens: passo 16, immagine 3 di 3
    • Remove the two 4 mm Phillips #000 screws securing the top button.
  17. GoPro Hero+ LCD Lens Replacement: passo 17, immagine 1 di 2 GoPro Hero+ LCD Lens Replacement: passo 17, immagine 2 di 2
    • Remove the four 4 mm Phillips #000 screws securing the lens to the case.
  18. GoPro Hero+ LCD Lens Replacement: passo 18, immagine 1 di 3 GoPro Hero+ LCD Lens Replacement: passo 18, immagine 2 di 3 GoPro Hero+ LCD Lens Replacement: passo 18, immagine 3 di 3
    • Gently lift the lens up and out of the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
USF Tampa, Team 2-4, Blackwell Fall 2015 Membro di USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Membri
20 Guide realizzate
2Commenti sulla guida
I'm curious if you have any suggestions for sourcing the replacement part.
Driftless Repair - Replica
My hing clip is broken, Can I remove the actual camera & replace the full waterproof case then reinstall my camera into the new replacement case ?
jimmac044 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 41
Tutti i Tempi: 6,745
