Salta al contenuto principale
GoPro Hero+ LCD Battery Replacement
Kyle
Kyle e 8 altri collaboratori
Ultimo aggiornamento il 20 mar 2025
5 minuti
Facile
Introduzione
Vai al passo 1
The battery is connected to the motherboard with a few wires. Be sure to be careful when removing the battery to not damage the motherboard or the battery.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. GoPro Hero+ LCD Battery Replacement, Back Panel: passo 1, immagine 1 di 2 GoPro Hero+ LCD Battery Replacement, Back Panel: passo 1, immagine 2 di 2
    • Be sure to power off the GoPro before you start disassembly.
    • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
    No parts required! What about the microSD/Micro USB assembly!!!! where to buy?!?!
    WPN - Replica
  2. GoPro Hero+ LCD Battery Replacement: passo 2, immagine 1 di 2 GoPro Hero+ LCD Battery Replacement: passo 2, immagine 2 di 2
    • Use the metal spudger to pry around the perimeter of the panel.
    • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
  3. GoPro Hero+ LCD Battery Replacement: passo 3, immagine 1 di 2 GoPro Hero+ LCD Battery Replacement: passo 3, immagine 2 di 2
    • Pry around the panel to ensure it is not attached to the device.
    • Move the panel to the side so you can access the internal components.
    • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
    а где можно купить вот этот шлейф соединяющий дисплей и плату.???
    Александр «ivkadre» Карпенко - Replica
  4. GoPro Hero+ LCD Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
    • Be careful of metal contacts on strip; they can be sharp.
  5. GoPro Hero+ LCD Battery Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, peel off the copper tape on the right side of the battery.
  6. GoPro Hero+ LCD Battery Replacement: passo 6, immagine 1 di 2 GoPro Hero+ LCD Battery Replacement: passo 6, immagine 2 di 2
    • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
  7. GoPro Hero+ LCD Battery Replacement: passo 7, immagine 1 di 1
    • Use a pair of tweezers to disconnect the battery connector from the motherboard.
    • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
    Lift the battery connector straight up.
    glenn tanner - Replica
    hi what kind battery can replace for hero+?
    sherwin_0011 - Replica
Conclusione
Altre 19 persone hanno completato questa guida.
Kyle
Membro da: 08/27/15
219 Reputazione
1 Guida realizzata
USF Tampa, Team 2-4, Blackwell Fall 2015 Membro di USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Membri
20 Guide realizzate
12Commenti sulla guida
This is a superb guide but where can one buy a replacement battery? I have looked on the web for the one in your photo but can't find a specific one.
I want to buy one of these cameras but would like to know I can replace the battery.
Thanks.
Andrew - Replica
I am also trying to find the replacement battery for a Hero+. Have found a lot of batteries for all other versions of Gopro cams, but not one single one for a Hero+.
I have also sent an email to Gopro to get help. I am not prepared for an answer but I really would like to get hold of a battery.
Does anyone know how to get one?
Please contact me: rhafsrhafs@gmail.com. Rikard from Sweden.
Thanks
Rikard
Rikard Hård -
hi, do you know where i can get the housing for the gopro hero+ lcd. mine is broken and need a new one but can't find it anywhere...........
chris
christianrisan - Replica
not even amazon?
Mary D'Alesandro -
this is awesome thanks a lot! , i dont want to be rude, but the title says battery replacementnt , why isnt anyone preparing a battery and putting it back in?, All everyone is doing is taking th battery out
John misquita - Replica
This is simply a teardown. Sorry for not being very helpful. There might be an update coming soon.
Mary D'Alesandro -
Nope not even on amazon or eBay, been lokking a long time now....
do you know, where to buy the battery???
beuermangabriel - Replica
pavel.novichkov - Replica
Hey, did anyone find out where to get a battery for the GoPro Hero + LCD ???
Not much point in pull the original one out if you can’t find a replacement…
tedkell1968 - Replica
Where can we buy the battery?
Mhenjill Artajo - Replica
Hi friends! I would like some help to find the specified battery GOPRO+ and buy it. How can I get, please? Thanks - marcos.caldana@yahoo.com.br
marcos.caldana - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 59
Ultimi 30 Giorni: 235
Tutti i Tempi: 39,356
