Gateway NV52 Optical Disc Drive Replacement
Introduzione
Vai al passo 1The Optical Disc Drive is not required to be taken out to have more access to the other components of the laptop.
Cosa ti serve
Remove the single 3/16" screw with the Phillips #0 Screwdriver that secures the Optical Drive.
Attrezzo utilizzato in questo passaggio:Heavy-Duty Spudger$4.99
Slightly wiggle the Optical Drive from the laptop using the Heavy Duty Spudger.
