Salta al contenuto principale
Garmin GPSmap 60CSx Screen Replacement
Thomas Humphrey
Thomas Humphrey e 6 altri collaboratori
Ultimo aggiornamento il 7 mag 2024
30 minuti
Moderato
Introduzione
Vai al passo 1
If the screen remains blank while the device is turned on, is cracked and unable to be used, or remains unresponsive, the screen may be broken and need to be replaced. The following are steps on how to replace the screen of the Garmin GPSmap 60CSx.
Cosa ti serve
Strumenti
Mostra di più…
  1. Garmin GPSmap 60CSx Screen Replacement, Back Cover and AA Batteries: passo 1, immagine 1 di 1
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Garmin GPSmap 60CSx Screen Replacement: passo 2, immagine 1 di 1
    • Lift battery release up to remove battery cover.
  3. Garmin GPSmap 60CSx Screen Replacement: passo 3, immagine 1 di 2 Garmin GPSmap 60CSx Screen Replacement: passo 3, immagine 2 di 2
    • Pull AA batteries out.
  4. Garmin GPSmap 60CSx Screen Replacement, Screen: passo 4, immagine 1 di 2 Garmin GPSmap 60CSx Screen Replacement, Screen: passo 4, immagine 2 di 2
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
    • Flip the back panel over to view the green electronics board (the PCB) and the PCB cover.
    • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
  5. Garmin GPSmap 60CSx Screen Replacement: passo 5, immagine 1 di 1
    • Take the spudger and place it in the bottom right corner of the black PCB cover.
    • Use the spudger to pry the corner out. This will need to be done to all four corners of the PCB cover.
    • It is best to do remove the bottom corners first.
    • Pull the PCB cover out of the GPSMap 60CSx.
  6. Garmin GPSmap 60CSx Screen Replacement: passo 6, immagine 1 di 2 Garmin GPSmap 60CSx Screen Replacement: passo 6, immagine 2 di 2
    • Carefully use the spudger to lift the PCB a few centimeters.
    • Pull the PCB towards the bottom of the GPSMap 60CSx.
    • This will pull the other components out of the GPSMap 60CSx like the antenna and the screen.
  7. Garmin GPSmap 60CSx Screen Replacement: passo 7, immagine 1 di 3 Garmin GPSmap 60CSx Screen Replacement: passo 7, immagine 2 di 3 Garmin GPSmap 60CSx Screen Replacement: passo 7, immagine 3 di 3
    • Apply light pressure to the four white tabs that are holding the screen in place.
    • The screen will now come off the PCB.
  8. Garmin GPSmap 60CSx Screen Replacement: passo 8, immagine 1 di 1
    • Turn the PCB over so the screen connector is facing you.
    • Move the screen out of the way for access to the screen connector.
  9. Garmin GPSmap 60CSx Screen Replacement: passo 9, immagine 1 di 3 Garmin GPSmap 60CSx Screen Replacement: passo 9, immagine 2 di 3 Garmin GPSmap 60CSx Screen Replacement: passo 9, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to pull the two white pins on the connector forward.
  10. Garmin GPSmap 60CSx Screen Replacement: passo 10, immagine 1 di 1
    • Remove the screen ribbon connector and screen.
Conclusione
Altre 5 persone hanno completato questa guida.
2Commenti sulla guida
i have a 60csx and the battery bounces the liquid, can help me?
salvador2707 - Replica
Thank you for these step by step detailed instructions.
jlciscorp - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 33
Tutti i Tempi: 5,053
