Salta al contenuto principale
Garmin DriveSmart 50 LMT Screen Replacement
Cosa ti serve
    1. Garmin DriveSmart 50 LMT Screen Replacement, Screen: passo 1, immagine 1 di 1
      • Use a T5 Torx screwdriver to remove the four screws from the bottom case.
      Chiedi a FixBot
      Aggiungi Commento
    2. Garmin DriveSmart 50 LMT Screen Replacement: passo 2, immagine 1 di 3 Garmin DriveSmart 50 LMT Screen Replacement: passo 2, immagine 2 di 3 Garmin DriveSmart 50 LMT Screen Replacement: passo 2, immagine 3 di 3
      • Use a plastic opening tool or metal spudger to separate the back cover from the front frame. Start from the corners and work your way around the device.
      • Carefully lift the back cover off to reveal the motherboard and ribbon cables.
      Chiedi a FixBot
      Aggiungi Commento
    3. Garmin DriveSmart 50 LMT Screen Replacement: passo 3, immagine 1 di 1
      • Use a spudger to unlock the screen cable ZIF connector.
      • Use angled sweezers to slide the cable from the socket.
      • You may need to flip the display assembly over for easier access to the display connector.
      Chiedi a FixBot
      Aggiungi Commento
    4. Garmin DriveSmart 50 LMT Screen Replacement: passo 4, immagine 1 di 2 Garmin DriveSmart 50 LMT Screen Replacement: passo 4, immagine 2 di 2
      • If the screen does not lift easily, use an iOpener to soften the adhesive.
      • Use a nylon spudger to pry the old display assembly.
      • The screen is held in place with adhesive, so be careful when removing it to avoid bending the frame.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Texas Tech, Team 41-5, Allen Fall 2025 Membro di Texas Tech, Team 41-5, Allen Fall 2025
TTU-ALLEN-F25S41G5
3 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 23
Tutti i Tempi: 124
