Salta al contenuto principale
GameStop GS3 GameCube Controller Buttons Replacement
Andrew Gonsalves
Andrew Gonsalves e 11 altri collaboratori
Ultimo aggiornamento il July 3, 2021
20 - 40 minuti
Moderato
Foto Azione
Introduzione
Vai al passo 1
After many hours of use, the buttons on the Gamecube Controller can become too loose or stick. This guide will provide instructions on how to replace the buttons of the GameStop GS3 Gamecube Controller. There are ten total buttons in this controller: left and right triggers, Z, turbo, D-pad, start/pause, A, B, X, and Y.
Cosa ti serve
  1. GameStop GS3 GameCube Controller Buttons Replacement, Back Panel: passo 1, immagine 1 di 3 GameStop GS3 GameCube Controller Buttons Replacement, Back Panel: passo 1, immagine 2 di 3 GameStop GS3 GameCube Controller Buttons Replacement, Back Panel: passo 1, immagine 3 di 3
    • First, remove the 6 screws in the back panel and pull the back panel off.
    • Separate the halves of the controller. However, be careful when separating due to the little wires that could get mixed up.
  2. GameStop GS3 GameCube Controller Buttons Replacement: passo 2, immagine 1 di 3 GameStop GS3 GameCube Controller Buttons Replacement: passo 2, immagine 2 di 3 GameStop GS3 GameCube Controller Buttons Replacement: passo 2, immagine 3 di 3
    • Next, remove the rumble motor by unscrewing the 2 screws connecting it.
  3. GameStop GS3 GameCube Controller Buttons Replacement: passo 3, immagine 1 di 3 GameStop GS3 GameCube Controller Buttons Replacement: passo 3, immagine 2 di 3 GameStop GS3 GameCube Controller Buttons Replacement: passo 3, immagine 3 di 3
    • Finally remove the screws holding in the right and left triggers. It's easiest to hold the trigger together as shown in the third picture. Remove both the left and right trigger, and then you have successfully removed your back panel.
  4. GameStop GS3 GameCube Controller Buttons Replacement, Buttons: passo 4, immagine 1 di 1
    • Hold the controller as shown in the picture so that you can remove the circuit board.
    • The locations of screws to be removed in future steps are shown in red.
  5. GameStop GS3 GameCube Controller Buttons Replacement: passo 5, immagine 1 di 2 GameStop GS3 GameCube Controller Buttons Replacement: passo 5, immagine 2 di 2
    • Now that the back panel has been removed it should be easy to snap off the "Z" and "TURBO" buttons as shown in the images.
  6. GameStop GS3 GameCube Controller Buttons Replacement: passo 6, immagine 1 di 1
    • Remove the two screws on the motherboard so that you can remove the motherboard from the front cover.
  7. GameStop GS3 GameCube Controller Buttons Replacement: passo 7, immagine 1 di 1
    • Now your controller front panel should look similar to this.
    • Remove the rubber backings on the buttons shown in red.
    • Snap them back in when you go to put the controller back together.
  8. GameStop GS3 GameCube Controller Buttons Replacement: passo 8, immagine 1 di 1
    • Remove the buttons and you should have what you see here.
Conclusione
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 Membro di UMass Dartmouth, Team 3-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G5
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,032
