Salta al contenuto principale
Fujitsu Lifebook Stylistic Q584 Camera Replacement
Connor Stanton
Connor Stanton e 4 altri collaboratori
Ultimo aggiornamento il January 5, 2018
6 minuti
Moderato
Foto Azione
Introduzione
Vai al passo 1
If you need to replace the camera this guide will provide step-by-step instructions on how to disassemble and replace your camera.
Cosa ti serve
Strumenti
Mostra di più…
  1. Fujitsu Lifebook Stylistic Q584 Camera Replacement, Back Case: passo 1, immagine 1 di 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 2, immagine 1 di 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 3, immagine 1 di 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Camera Replacement, Inner Back Shield: passo 4, immagine 1 di 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 5, immagine 1 di 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 6, immagine 1 di 1
  7. Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 7, immagine 1 di 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Camera Replacement, Camera: passo 8, immagine 1 di 2 Fujitsu Lifebook Stylistic Q584 Camera Replacement, Camera: passo 8, immagine 2 di 2
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 9, immagine 1 di 2 Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 9, immagine 2 di 2
    • Pull the ribbon straight up from the back of the camera board
  10. Fujitsu Lifebook Stylistic Q584 Camera Replacement: passo 10, immagine 1 di 1
    • Remove the single 2mm screw using a PH000 screwdriver from the camera board.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 349
