Salta al contenuto principale
Fujifilm FinePix XP80  Shutter Button Replacement
Daniela Pesci
Daniela Pesci e 4 altri collaboratori
Ultimo aggiornamento il May 3, 2020
20 - 25 minuti
Facile
Introduzione
Vai al passo 1
The shutter button is the main communication point between you and your camera's main function: taking photos. When it's malfunctioning, you'll need a way to fix it. This guide will help you do just that.
Cosa ti serve
Strumenti
Mostra di più…
  1. Fujifilm FinePix XP80  Shutter Button Replacement, Battery: passo 1, immagine 1 di 3 Fujifilm FinePix XP80  Shutter Button Replacement, Battery: passo 1, immagine 2 di 3 Fujifilm FinePix XP80  Shutter Button Replacement, Battery: passo 1, immagine 3 di 3
    • Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
  2. Fujifilm FinePix XP80  Shutter Button Replacement: passo 2, immagine 1 di 1
    • Release the battery from its secured position by pulling the orange tab back. The battery can then be removed from its compartment.
  3. Fujifilm FinePix XP80  Shutter Button Replacement, Exterior Case: passo 3, immagine 1 di 1
    • Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
  4. Fujifilm FinePix XP80  Shutter Button Replacement: passo 4, immagine 1 di 1
    • Using a H1.3 hex head bit, remove the two 2mm screws from the top of the camera.
  5. Fujifilm FinePix XP80  Shutter Button Replacement: passo 5, immagine 1 di 1
    • Using a H1.3 hex head bit, remove the two 2mm screws on the side of the camera.
  6. Fujifilm FinePix XP80  Shutter Button Replacement: passo 6, immagine 1 di 1
    • Using a plastic opening tool, gently pry up the edge of the button case, located at the top of the camera, until it unclips.
  7. Fujifilm FinePix XP80  Shutter Button Replacement: passo 7, immagine 1 di 1
    • Gently pry the side area of the case apart.
  8. Fujifilm FinePix XP80  Shutter Button Replacement: passo 8, immagine 1 di 1
    • Continue using the opening tool on the bottom of the camera to gently pry the case apart.
  9. Fujifilm FinePix XP80  Shutter Button Replacement: passo 9, immagine 1 di 2 Fujifilm FinePix XP80  Shutter Button Replacement: passo 9, immagine 2 di 2
    • Use the plastic opening tool to carefully pry the yellow front panel completely away from the camera.
    • Use your hands to take off the yellow back panel.
  10. Fujifilm FinePix XP80  Shutter Button Replacement, Shutter Button: passo 10, immagine 1 di 2 Fujifilm FinePix XP80  Shutter Button Replacement, Shutter Button: passo 10, immagine 2 di 2
    • Once the exterior case is removed, separate the plastic depressor to ensure there is nothing lodged in or around the button, preventing proper functionality.
Conclusione
Daniela Pesci
Membro da: 09/28/16
194 Reputazione
2 Guide realizzate
USF Tampa, Team 1-3, Cagle Fall 2016 Membro di USF Tampa, Team 1-3, Cagle Fall 2016
USFT-CAGLE-F16S1G3
5 Membri
14 Guide realizzate
2Commenti sulla guida
Do you know where I can get replacement shutter button parts for this camera.
DEAN MURPHY - Replica
Where can I buy the shutter button components for this camera?
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 849
