Fujifilm FinePix S8200 Batteries Replacement
Introduzione
Vai al passo 1This camera runs on 4 AA batteries. Let's learn how to replace them. This is the simplest maintenance task that you will perform on this camera.
Insert your new batteries, close the battery chamber, and you're done!
3 Commenti
should there be an indicator led to show the camera is charing ?
should the camera indicate that it is being charged ?
When changing battery the date and time is reset. Is there a backup battery ?
