Salta al contenuto principale
Fujifilm FinePix S4800 LCD Screen Replacement
Stephen Calabrese
Stephen Calabrese e un altro collaboratore
Ultimo aggiornamento il April 24, 2020
10 - 15 minuti
Moderato
Introduzione
Vai al passo 1
In this guide, we will be taking apart the Fujifilm FinePix S4800 to remove and replace the LCD screen. This involves taking off the rear plastic case of the camera by removing screws and using a plastic removal tool to separate the rear case from the rest of the camera. Then, only one ZIF connector stands between you and a new LCD screen.
Cosa ti serve
Strumenti
Mostra di più…
  1. Fujifilm FinePix S4800 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure that the camera is powered off before continuing.
    • Rotate the camera so that the label on the base of the camera is facing up.
    • On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
  2. Fujifilm FinePix S4800 LCD Screen Replacement: passo 2, immagine 1 di 3 Fujifilm FinePix S4800 LCD Screen Replacement: passo 2, immagine 2 di 3 Fujifilm FinePix S4800 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Remove all four batteries and set them aside.
    • When replacing the batteries, be sure to note the markings on the face of the battery compartment. These markings let you know which side of the battery ("+" or "-") needs to be facing up in each slot.
  3. Fujifilm FinePix S4800 LCD Screen Replacement, Rear Case: passo 3, immagine 1 di 1
    • Remove the three 5.0 mm JIS #000 screws on the bottom of the camera.
  4. Fujifilm FinePix S4800 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Rotate the camera so that the HDMI port is facing up.
    • Remove the two 5.0 mm JIS #000 screws.
  5. Fujifilm FinePix S4800 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Rotate the camera so that the text "30x superwide 24-720mm" is facing up.
  6. Fujifilm FinePix S4800 LCD Screen Replacement: passo 6, immagine 1 di 3 Fujifilm FinePix S4800 LCD Screen Replacement: passo 6, immagine 2 di 3 Fujifilm FinePix S4800 LCD Screen Replacement: passo 6, immagine 3 di 3
    • Press the pop-up button highlighted in the picture to release the flash mechanism.
    • Remove the two 5.0 mm JIS #000 screws highlighted in the picture.
  7. Fujifilm FinePix S4800 LCD Screen Replacement: passo 7, immagine 1 di 3 Fujifilm FinePix S4800 LCD Screen Replacement: passo 7, immagine 2 di 3 Fujifilm FinePix S4800 LCD Screen Replacement: passo 7, immagine 3 di 3
    • Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated.
    • The plastic case is fragile, so take your time on each side making sure to pry each side evenly as you continue around the camera with the tool.
  8. Fujifilm FinePix S4800 LCD Screen Replacement: passo 8, immagine 1 di 2 Fujifilm FinePix S4800 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Gently, remove the rear case from the camera and set it aside.
  9. Fujifilm FinePix S4800 LCD Screen Replacement, LCD Screen: passo 9, immagine 1 di 3 Fujifilm FinePix S4800 LCD Screen Replacement, LCD Screen: passo 9, immagine 2 di 3 Fujifilm FinePix S4800 LCD Screen Replacement, LCD Screen: passo 9, immagine 3 di 3
    • At this point, it is highly recommended that you wear an ESD wristband to prevent damage to the internal electronic components.
    • With respect to the camera that was disassembled for this guide, the LCD display easily fell out of its housing after the rear case was removed. If your screen fits more tightly, you can use a plastic removal tool to gently pry up one of the edges of the screen and that will release it from its mount.
    • Gently tilt the LCD screen toward the bottom of the camera and use a spudger to flip the lock for the ZIF cable attached to the LCD.
  10. Fujifilm FinePix S4800 LCD Screen Replacement: passo 10, immagine 1 di 1
    • Lift the screen away from the camera and set it aside.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S19-G4, Hoffman Spring 2017 Membro di USF Tampa, Team S19-G4, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G4
4 Membri
16 Guide realizzate
2Commenti sulla guida
Thank you Stephen for this tutorial. I have two hobbies, photography and video games, especially in games, I am fascinated by music. I know that licensing music for developers is a long process, but thanks to a service like https://www.styngr.com/ music licensing for developers won't be a problem
Sean Foden - Replica
It's easy to agree that, it's very hard to find a reputable and trustworthy online casino. The only casino I can recommend is GG Bet promokod casino because people trust it. According to statistics https://crongdor.com/ this online casino has the highest RTP.
Дмитрий Куб - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 36
Tutti i Tempi: 1,111
