Salta al contenuto principale
Fujifilm FinePix HS30EXR Screen Replacement
Andrew Scouten
Andrew Scouten e 4 altri collaboratori
Ultimo aggiornamento il January 3, 2023
20 minuti
Moderato
Introduzione
Vai al passo 1
This guides serves to help the user replace the LCD Screen.
Warning: The replacement of the screen requires great care, as any force could damage the frame or any internal cables/wires that may be essential to the camera's function. To avoid damage, treat the frame with care when prying it off, and treat and wires or cables with care as well.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Fujifilm FinePix HS30EXR Screen Replacement, Frame: passo 1, immagine 1 di 1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Screen Replacement: passo 2, immagine 1 di 1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Screen Replacement: passo 3, immagine 1 di 1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Screen Replacement: passo 4, immagine 1 di 1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
    That's a bit misleading it's a spring clip at the bottom of the hot shoe
    Colin Head - Replica
  5. Fujifilm FinePix HS30EXR Screen Replacement: passo 5, immagine 1 di 1
  6. Fujifilm FinePix HS30EXR Screen Replacement: passo 6, immagine 1 di 1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Screen Replacement: passo 7, immagine 1 di 2 Fujifilm FinePix HS30EXR Screen Replacement: passo 7, immagine 2 di 2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Screen Replacement, Screen: passo 8, immagine 1 di 1
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Screen Replacement: passo 9, immagine 1 di 1
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Screen Replacement: passo 10, immagine 1 di 1
    • Now that the ribbon cable is unconnected, pull away the frame to work on.
  11. Fujifilm FinePix HS30EXR Screen Replacement: passo 11, immagine 1 di 1
    • Flip the frame component so that the inside is now accessible.
    • With a screwdriver, unscrew all highlighted screws.
  12. Fujifilm FinePix HS30EXR Screen Replacement: passo 12, immagine 1 di 1
    • Flip the LCD Screen component so that the bottom half is now accessible.
  13. Fujifilm FinePix HS30EXR Screen Replacement: passo 13, immagine 1 di 1
    • Remove the LCD Screen component from its mount.
    • Turn the LCD Screen component so that the right side is now accessible.
  14. Fujifilm FinePix HS30EXR Screen Replacement: passo 14, immagine 1 di 1
    • The LCD Screen can now be removed from the LCD Screen Mount.
    • Carefully remove the LCD Screen, as it is attached by another ribbon cable.
  15. Fujifilm FinePix HS30EXR Screen Replacement: passo 15, immagine 1 di 1
    • To remove the LCD Screen, flip the switch on the ribbon cable's container that is closest to the ribbon cable (highlighted by the red circle).
    • Carefully remove the ribbon cable from its compartment, and remove the LCD Screen.
    • Position your new LCD Screen onto where the old one was removed from, and reattach the ribbon cable (ensure that the switch is now clamped down; a light tug should not dislodge the ribbon cable).
Conclusione
Altre 4 persone hanno completato questa guida.
Baylor, Team S1-G2, Williams Fall 2018 Membro di Baylor, Team S1-G2, Williams Fall 2018
BU-WILLIAMS-F18S1G2
4 Membri
12 Guide realizzate
2Commenti sulla guida
Ecran de rechange trouvé chez elecok.
Tuto testé, fonctionne aussi pour le Fuji HS20 EXR.
Bravo et Merci à Andrew et aux contributeurs
Bernard MRT - Replica
Thanks I have fixed the screen on my camera now it works perfect
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 31
Tutti i Tempi: 2,820
