Fujifilm FinePix HS30EXR Lens Replacement
Introduzione
Vai al passo 1This guides is meant to be used with the intention to replace the lens.
Warning: The lens is very fragile; any scrape or fingerprint could result in a unusable lens. Take great caution in the replacement of the lens.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
Flip the camera so that the bottom is facing upwards.
With the Phillips #00 screwdriver, remove all four screws.
Slowly and carefully pull the frame away to have a better view of the inside.
Once the motherboard is taken out, with a screwdriver, unscrew all highlighted screws.
Take the lens off once it is unscrewed.
Altre 3 persone hanno completato questa guida.
