Salta al contenuto principale
Fleetwood Monarch 62" Recurve Bow String Replacement
Zachery Kail
Zachery Kail e un altro collaboratore
Ultimo aggiornamento il August 8, 2023
10 minuti
Moderato
Introduzione
Vai al passo 1
Recurve bows are a type of traditional bow that have been used for hundreds of years across multiple cultures. Whether used for hunting or sport, monitoring the condition of your bow string is crucial for maintaining accuracy and consistency. If your string is broken or worn, this guide will show you how to replace your bow string on a Fleetwood Monarch 62" recurve bow, without the use of any tools. This option will save you money since it doesn't require tools or the purchase of a new bow.
This procedure requires a bit of physical strength, but can be done using the right leverage.
Precautions must be taken when removing the string and restringing your bow due to the amount of tension created. Make sure the bow is not facing you and that your hands are clear of the bow string when replacing the bow string.
Safety glasses are recommended.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Fleetwood Monarch 62" Recurve Bow String Replacement, String: passo 1, immagine 1 di 1
    • Remove the broken or damaged bow string.
  2. Fleetwood Monarch 62" Recurve Bow String Replacement: passo 2, immagine 1 di 1
    • One end of the new bowstring will have a loop with a larger diameter than the other. Take the larger loop and secure it onto one end of the bow.
  3. Fleetwood Monarch 62" Recurve Bow String Replacement: passo 3, immagine 1 di 1
    • Slide the larger loop halfway down the limb of the bow.
  4. Fleetwood Monarch 62" Recurve Bow String Replacement: passo 4, immagine 1 di 1
    • Secure the smaller loop onto the other end of the bow.
  5. Fleetwood Monarch 62" Recurve Bow String Replacement: passo 5, immagine 1 di 3 Fleetwood Monarch 62" Recurve Bow String Replacement: passo 5, immagine 2 di 3 Fleetwood Monarch 62" Recurve Bow String Replacement: passo 5, immagine 3 di 3
    • Place your left leg between the bow shaft and the bow string.
    • Place your foot behind the end of the bow touching the ground.
    • Place one hand near the middle of the bow and the other hand on the string, close to the larger loop.
    • Push down on the top end of the bow and slide the larger loop into place.
Conclusione
Enjoy your new bow-string!
Zachery Kail
Membro da: 09/16/20
121 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 18
Tutti i Tempi: 948
