Salta al contenuto principale
Fixing the Error Code 165-6596
ChrisLord9
ChrisLord9 e 2 altri collaboratori
Ultimo aggiornamento il November 12, 2023
5 - 15 minuti
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
This error always occurs on any amiibo compatible game/software (except for Mario Kart 8 if not on the amiibo Mii suits section), due to the NFC board being either disconnected from the GamePad or completely fried. In this tutorial, you will reseat the NFC board back to where it belongs.
Credit: Mod and Pop Thrift (the original video)
Cosa ti serve
Strumenti
Mostra di più…
  1. Fixing the Error Code 165-6596, Removing the stylus and battery lid: passo 1, immagine 1 di 2 Fixing the Error Code 165-6596, Removing the stylus and battery lid: passo 1, immagine 2 di 2
    • Remove the stylus. This in order to correctly remove the back cover
    • Unscrew the battery lid with the P00 Philps Screwdriver.
  2. Fixing the Error Code 165-6596, Removing the battery: passo 2, immagine 1 di 1
    • After removing the lid, carefully remove the cable connecting the battery to the motherboard and lift up the battery
  3. Fixing the Error Code 165-6596, Removing the back cover: passo 3, immagine 1 di 1
    • Remove the screw covers with the pick and use the Tri-wing Screwdriver to unscrew the remaining screws around the GamePad.
    • Lift up the back cover
    • Lift up gently, as the rumble motor is attached
  4. Fixing the Error Code 165-6596, Reseating the NFC board: passo 4, immagine 1 di 1
    • I have put a circle around the correct placement of the NFC board. This is how it should look like.
    • If the NFC board is detached, gently reseat it back to where it was.
    • If the NFC board seated correctly, gently remove and gently reseat it.
Conclusione
To reassemble your device, follow these instructions from Step 3 in reverse order. If the problem persists (even after multiple attempts), it might be time to order a replacement part.
Altre 2 persone hanno completato questa guida.
ChrisLord9
Membro da: 01/06/23
307 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 54
Tutti i Tempi: 2,456
