Fan Removal
Introduzione
Vai al passo 1This guide shows how to remove the fan in your Xbox Series X (Digital Edition) gaming console.
Cosa ti serve
Strumenti
Mostra di più…
Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$19.95
Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
Pry up the back panel to release it from the locking clips.
Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
One 10.3 mm‑long pancake screw
Two 9 mm‑long screws
Use your fingernails or a pair of angled tweezers to firmly grip the edges of the fan cable connector.
Pull the connector straight out of the socket to disconnect it.
Attrezzo utilizzato in questo passaggio:Dust Blower$18.99
Slide the fan out of its slot to remove it.
Before installing the fan, make sure it's clean! Use a dust blower or compressed air to blow off any dust or debris, and wipe the fan clean with a clean cloth.
Note that the fan can only be installed one way—make sure Master Chief is facing you.
