Fan Rebuild
Unscrew the 2 screws that are hidden under fan blades ⚠️BLADES MAY BE HOT AFTER RUNNING FOR 1 HR(s)+
Remove the fan Blades ⚠️USE GLOVES! BLADES AND BOTTOM HALF MAY BE HOT AFTER USE!!⚠️
Unscrew 2 screws ⚠️ BOTTOM PART MAY FALL.. HOLD BOTTOM PART JUST INCASE ⚠️
Redo the steps to rebuild ⚠️DO NOT TOUCH WIRES UNLESS YOU KNOW WHAT YOUR DOING ⚠️
Altre 4 persone hanno completato questa guida.
