Salta al contenuto principale
Fairphone 2 Headphone Module Replacement
Tobias Isakeit
Tobias Isakeit e 2 altri collaboratori
Ultimo aggiornamento il 20 mag 2019
5 - 10 minuti
Moderato
Introduzione
Vai al passo 1
This guide will show you how to replace the headphone module of the Fairphone 2.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Fairphone 2 Headphone Module Replacement, Slim Case: passo 1, immagine 1 di 3 Fairphone 2 Headphone Module Replacement, Slim Case: passo 1, immagine 2 di 3 Fairphone 2 Headphone Module Replacement, Slim Case: passo 1, immagine 3 di 3
    • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
    • Pull up the back part of the slim case to separate the small snap fit connections.
    • Remove the back part of the slim case.
  2. Fairphone 2 Headphone Module Replacement: passo 2, immagine 1 di 3 Fairphone 2 Headphone Module Replacement: passo 2, immagine 2 di 3 Fairphone 2 Headphone Module Replacement: passo 2, immagine 3 di 3
    • Get in between the front part of the slim case and the phone's body with your thumb nail.
    • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
  3. Fairphone 2 Headphone Module Replacement: passo 3, immagine 1 di 1
    • Remove the front part of the slim case.
  4. Fairphone 2 Headphone Module Replacement, Battery: passo 4, immagine 1 di 3 Fairphone 2 Headphone Module Replacement, Battery: passo 4, immagine 2 di 3 Fairphone 2 Headphone Module Replacement, Battery: passo 4, immagine 3 di 3
    • Push the battery toward the top of the phone.
    • Pull the battery out away from the phone.
    It isn't necessary to remove the rim if all you are doing is changing the battery. That becomes necessary if you are to proceed farther into the phone.
    It might be good to begin by saying switch the phone off. The Fairphone is for everybody and most will have no experience of disassembling electronic devices.
    Jim Kinnibrugh - Replica
  5. Fairphone 2 Headphone Module Replacement, Display Assembly: passo 5, immagine 1 di 3 Fairphone 2 Headphone Module Replacement, Display Assembly: passo 5, immagine 2 di 3 Fairphone 2 Headphone Module Replacement, Display Assembly: passo 5, immagine 3 di 3
    • After taking out the battery you can unlock the display assembly.
    • Flip the two blue switches to the inner position.
    • Slide the display assembly towards the bottom of the phone.
    Being technically nervous I couldn't do this. I didn't know how much pressure, pull or push was required.
    Roger Halford - Replica
    After I'd watched the video my confidence increased!
    It was a bit stiff and not so easy.
    M ichael Cross - Replica
    I have not this easy access to the two blue switches. How Can I do that?
    Anne - Replica
    Super, nachdem ich’s im Video gesehen habe, war es supereasy, vielen Dank!
    Imke - Replica
    You don´t mention taking the rim off the display first. That stymied me completely. Do add that to your otherwise clear and helpful instructions. Best wishes - Walt Patterson
    Walt Patterson - Replica
    This guide is based on the old bumper made in one piece. We should update to the sandwich bumper with a top and bottom part.
    Tobias Isakeit -
    I agree. Took a while to figure that one out!
    Jenny White -
    Sorry, I can not slide away the display assembly to change the main camera module. The 2 blue switches seem to be locked. Cristiano, Italy
    Cristiano Gillardi - Replica
    I replay to myself: I did it at last! ! But it was very, very, very, very hard!
    Can’t get any movement at all on screen been trying for over an hour and others too ! there is no way to grip it as its so slippery have tried putting as much presure as possible on display by pushing far end of it with thin plastic implement and endless wiggling and pressing of every possible part of lower case no joy ! feels like its attached at mid sides. Elinor Rivers
    Elinor Rivers - Replica
    try sliding along the display while applying some pressure two or three times. it worked really easily for me
    Elisa Werner - Replica
    I could slide the display case off very easily after watching the video, but when it came to doing the sequence in reverse I was fiddling about for ages trying to ‘slide’ it back on, until I realised this just wasn’t going to work and needed to click it back into place. Posting here in case this is helpful for others.
    Rachel Neat - Replica
    • Another possible way of sliding the display assembly open.
    Impossible de déplacer l'écran vers le bas chez moi. Je n'ose pas forcer... c'est normal?
    benbahmedf - Replica
    I can not slide the display assembly. Some help?
    Laura Ivorra - Replica
    The display sits very tight.
    So you need to gently apply a little force to slide it open the first time.
    It is hard to get a good grip on the two parts for a successful "magic move".
    Tobias Isakeit - Replica
    Leider kann ich weder mit "little force" noch mit "much force" das Display nach der Entriegelung bewegen. Wer kann mit mehr Details helfen?
    Christine Heckmann - Replica
    It did work for me. Make sure, you have unlocked the blue switches in step 3 (sorry, had to mention that). if you can't get a grip, you might try to lay a ruler or two credit cards on top of each other on a table that is tight at the wall,
    - place the ruler/credit cards on the table and just attaching the wall
    - place the PF2 with the display upside down on the table in front of the ruler/credit cards with the blue switches towards you and the headphone plug attaching the ruler/cards.
    - then gently but with increasing force push your two thumbs towards the top of the main FP2 unit (or use more fingers to push both in the centre as well as on the two edges). make sure you push horizontally and that the ruler is not higher than the border of the display unit (1.5-2 mm).
    (hope i could explain myself in and understandable way! ;-) )
    metaworx - Replica
    Thank you a lot ! This worked for me.
    Nicolas Dudermel -
    Thanks, it worked for us as well.
    deRahier -
    great tip! Thanks so much
    Matthew Kelly -
    Really helped! This way finally worked for me. Thanks :)
    Imogen Michel -
    thank you !!
    Claire Hahn -
    Perfect Metaworx, it worked for me as well :)
    siohdk - Replica
    Your nails are slightly long? You are lucky. Hold the phone with the screen on your right palm with the blue bits facing your body. Make sure your fingernails are holding the top of the screen. Push the back of the phone with your left hand. It worked for me.
    Askateth - Replica
    Mit einer alten Haltekarte für SIM Cards als Hebel habe ich das Display vorsichtig abgeschoben
    Joachim - Replica
    Unglaublich fair, dass ich mich mit diesem Kack alleine beschäftige - wenn ich so weitermache, werde ich demnächst die Trümmer meines Fairphones wahrscheinlich durch Ungeschicklichkeit so beschädigen, dass es unbrauchbar ist!
    Ralf Kiefer - Replica
  6. Fairphone 2 Headphone Module Replacement: passo 7, immagine 1 di 1
    • Take off the display assembly.
  7. Fairphone 2 Headphone Module Replacement, Headphone Module: passo 8, immagine 1 di 1
    • Remove the two Phillips #0 screws of the headphone module marked by the blue circles.
    Tips for doing this:
    - don't use a Pozidriv (PZ) screw, only a Philips
    - 00 will probably work better than 0
    - turn the screw anti-clockwise to get it out
    if it clicks and doesn't come out, stop at the point just after it clicks - you should be able to shake it out (https://linustechtips.com/main/topic/200...)
    - buy a replacement for any screws that are awkward to get out, rather than putting them back in
    Matt Clear - Replica
  8. Fairphone 2 Headphone Module Replacement: passo 9, immagine 1 di 3 Fairphone 2 Headphone Module Replacement: passo 9, immagine 2 di 3 Fairphone 2 Headphone Module Replacement: passo 9, immagine 3 di 3
    • Turn the mainframe around so you're looking at it from the back and can see the two blank parts of the module.
    • Take out the module by first pushing the left part out with your thumb while holding the right side in place.
    • Then push out the right part with your other thumb.
Conclusione
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
Altre 37 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Tobias Isakeit
Membro da: 03/31/14
125.946 Reputazione
189 Guide realizzate
10Commenti sulla guida
Die beiden Schrauben, die blau gekennzeichnet sind - es sind vier Schrauben. Soweit bin ich jedoch nicht gekommen, da der Bildschirm sich auf beide genannten Weisen nicht abschieben lässt. Schraubstock und leichte Schläge mir einem breiten Schraubenzieher werden keine sinnvollen Werkzeuge sein. Schraubenzieher: Im Baumarkt gibt es keinen PH 0 sondern PH 0 x 60. Der Verkäufer meinte, es müsste der PH 00 x 60 sein; also beide mitgenommen. Zum Testen, welcher der richtige ist, bin ich nicht gekommen, siehe oben. Vielleicht sind auch beide falsch und es gibt per Internet tatsächlich den PH 0. Außerdem muss ich nicht das Kopfhörerteil austauschen, sondern den Lautsprecher, den ich nach Schwierigkeiten inzwischen erhalten habe. Über Lautsprecheraustausch finde ich keine Anleitung. cw@actanol.de
carstenwitt41 - Replica
Hallo, die zwei blauen Schrauben lösen das Modul vom Rahmen, die beiden anderen sind Torx Schrauben und öffnen das Modul selbst. Das Display sitzt recht fest und muss ein wenig lose gewackelt werden. Eventuell hilft es Gummihandschuhe zu verwenden oder das Fairphone mit der Displayseite auf eine rutschfeste Matte zu legen und dann durch Hin-und Herbewegen zu lockern. Die Anleitung für das Mikrofonmodul zeigt, dass darin auch den Lautsprecher sitzt: Sostituzione modulo del microfono Fairphone 2
Tobias Isakeit -
Um einen Fussel aus der Klinkenbuchse zu entfernen, benötigt man zusätzlich zum Philips #0 ,
einen Torx #5 um die beiden kleinen Schrauben zu lösen. Die Metallklammern solten kein Problem darstellen.
Thomas Siegl -
Nach dem Tausch muss der Näherungssensor (Proximity Sensor) neu kalibriert werden, sonst bleibt das Display beim Telefonieren immer schwarz!
Einstellungen->System->Wartung->Näherungssensor
Florian Steinle - Replica
Worked flawlessly. Thank you.
So for those of you not speaking english - it can be a good idea to calibrate the proximity sensor after replacing the module (the sensor that blanks (blacks) the screen when holding the phone to your ear).
Settings - Maintenance - Proximity Sensor
johan - Replica
Hilfe…ich habe den Sensor kalibriert über den Nährungssensor. Seitdem habe ich mehrere fehler: ich kann die obere Leiste nicht mehr herunterwischen, wo Wlan, Ton, Bluetooth, Einstellungen einzusehen sind, der rechte untere seitliche Button zum Aktivieren der Kamera geht nicht mehr und auf dem Display ist der mittlere runde und der rechte viereckige Button nicht mehr zum Aktivieren… Ich habe nochmal ein Update gemacht vom gesamten Handy, auch damit keinen Erfolg…
Wer kann mir helfen???
Brendler Barbara - Replica
Awesome. Did this and the camera module. It’d be great if it gave guidance at the end as to where to send the old parts for recycling, thus completing the circle. Thanks fairphone and great guide Tobias!
Charlotte Workman - Replica
Hat prima funktioniert dank einfacher Anleitung und einfacher Bauweise. Auch die anschliessende Kalibrierung des Sensors war völlig unproblematisch. Alles bestens!
Christian Heider - Replica
Great instructions - very easy to use. Thanks a lot!
Damion Milliken - Replica
Grandios! echt einfach mit dieser klaren Anleitung, DANKE!
Melanie Eberhardt - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 67,538
