Salta al contenuto principale
Epson VS240 Lens Replacement
Cosa ti serve
    1. Epson VS240 Lens Replacement, Shell: passo 1, immagine 1 di 3 Epson VS240 Lens Replacement, Shell: passo 1, immagine 2 di 3 Epson VS240 Lens Replacement, Shell: passo 1, immagine 3 di 3
      • Using the Phillips #2 screwdriver, loosen the single captive screw on the left side of the projector.
      • The captive screw will loosen, but it cannot be fully removed.
      • Slide the panel off and remove it from the device.
      Chiedi a FixBot
      Aggiungi Commento
    2. Epson VS240 Lens Replacement: passo 2, immagine 1 di 2 Epson VS240 Lens Replacement: passo 2, immagine 2 di 2
      • Use the Phillips #2 screwdriver to remove the three 5 mm screws.
      • Using the same Phillips #2 screwdriver, remove the single 8 mm silver screw.
      Chiedi a FixBot
      Aggiungi Commento
    3. Epson VS240 Lens Replacement: passo 3, immagine 1 di 1
      • Use a Phillips #1 screwdriver to remove the two 10 mm silver screws from the bottom of the device.
      Chiedi a FixBot
      Aggiungi Commento
    4. Epson VS240 Lens Replacement: passo 4, immagine 1 di 1
      • Use a Phillips #1 screwdriver to remove the single 10 mm screw where the panel was removed in Step 1.
      • Remove the white back plate from the device.
      Chiedi a FixBot
      Aggiungi Commento
    5. Epson VS240 Lens Replacement: passo 5, immagine 1 di 3 Epson VS240 Lens Replacement: passo 5, immagine 2 di 3 Epson VS240 Lens Replacement: passo 5, immagine 3 di 3
      • Flip the projector over so that the underside (side with the feet) is facing you.
      • Use a Phillips #1 screwdriver to remove five 10 mm screws on the underside of projector.
      • Using the same Phillips #1 screwdriver, remove a single 10 mm screw in the center hole.
      • You may need to use a screwdriver extender to reach the single screw.
      Chiedi a FixBot
      Aggiungi Commento
    6. Epson VS240 Lens Replacement: passo 6, immagine 1 di 3 Epson VS240 Lens Replacement: passo 6, immagine 2 di 3 Epson VS240 Lens Replacement: passo 6, immagine 3 di 3
      • Use a Phillips #1 screwdriver to remove two 10 mm screws from the openings on each side of the air filter, on the topside of the projector.
      • You may need to use a screwdriver extender to reach the two screws.
      • Using the same Phillips #1 screwdriver, remove the two 10 mm screws where the white panel was removed on the topside of the projector in Step 1.
      Chiedi a FixBot
      Aggiungi Commento
    7. Epson VS240 Lens Replacement: passo 7, immagine 1 di 2 Epson VS240 Lens Replacement: passo 7, immagine 2 di 2
      • Be careful when removing the top cover of projector as there is as white ribbon cable connecting it to the motherboard.
      • Gently lift top cover and place it on its top next to the projector so that the ribbon has no tension on it.
      • Gently pull the brown tape connecting the cable to the motherboard and then remove the shell from the device.
      Chiedi a FixBot
      Aggiungi Commento
    1. Epson VS240 Lens Replacement, Motherboard: passo 8, immagine 1 di 2 Epson VS240 Lens Replacement, Motherboard: passo 8, immagine 2 di 2
      • Using a spudger or a plastic opening tool, disconnect all of the wires connected to the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    2. Epson VS240 Lens Replacement: passo 9, immagine 1 di 2 Epson VS240 Lens Replacement: passo 9, immagine 2 di 2
      • Using the Phillips #1 screwdriver, remove three 6 mm screws.
      • Using the same Phillips #1 screwdriver, remove a single 10 mm screw in bottom right corner of motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    3. Epson VS240 Lens Replacement: passo 10, immagine 1 di 2 Epson VS240 Lens Replacement: passo 10, immagine 2 di 2
      • Using a spudger or your fingernails, lift up the black locking tabs and disconnect the three ribbon cables from the motherboard.
      • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
      • Using the Phillips #1 screwdriver, remove three 10 mm screws on the grey piece that is located on the side of the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    4. Epson VS240 Lens Replacement: passo 11, immagine 1 di 1
      • Lift and remove the motherboard up and away from the device.
      Chiedi a FixBot
      Aggiungi Commento
    1. Epson VS240 Lens Replacement, Lens: passo 12, immagine 1 di 2 Epson VS240 Lens Replacement, Lens: passo 12, immagine 2 di 2
      • Rotate the projector 180 degrees to match orientation in images.
      • Using the Phillips #2 screwdriver, remove four inner 11 mm screws under the black box connected to the lens.
      • These screws are located deep into the projector and you may need a screwdriver extender to reach two of the four screws.
      Chiedi a FixBot
      Aggiungi Commento
    2. Epson VS240 Lens Replacement: passo 13, immagine 1 di 2 Epson VS240 Lens Replacement: passo 13, immagine 2 di 2
      • Detach the wire above the lens using plastic pry bar.
      • These wires can also be removed by hand; however, a plastic opening tool may be used for more prying power.
      • Slowly lift the black assembly out of the device.
      • Be careful of the wire still connected. It does not need to be removed so lay the black assembly close to the projector so no tension is on the wire.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Vincent Brown
Membro da: 09/28/21
105 Reputazione
Una guida realizzata
Clemson, Team 5-3, Hunter Fall 2021 Membro di Clemson, Team 5-3, Hunter Fall 2021
CLEM-HUNTER-F21S5G3
5 Membri
18 guide realizzate
1Commento della guida
This guide helped me remove the lens assembly and reassemble in about 1 hour. Well done guide.
DFixitGuy - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 21
Tutti i Tempi: 541
