Epson Stylus Photo 1400 Ink cartridge replacement
Introduzione
Vai al passo 1This guide shows how to replace an Ink Cartridge. This process requires no necessary tools or knowledge of the device.
Cosa ti serve
Ricambi
Open cover of the printer.
Open the cartridge cover by pressing down on the tab and lifting it up.
Altre 2 persone hanno completato questa guida.
6Commenti sulla guida
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
Instruction intimates the ink carriage will be in position when parked. Not so…with it parked in the extreme right, you cannot get the ink cover open. jdw
