Epson EX90 Cooling Fan Replacement
Introduzione
Vai al passo 1The Epson EX90 projector cooling fan is a vital component of the machine which regulates internal temperatures of device. If not replaced properly, a faulty cooling fan could begin to cause a variety of hard to solve problems. A bad fan may make loud and unusual noises when cooling, or if broken the device may begin to overheat. Caution will be required when opening cover, as attached ribbons breaking could damage the motherboard.
Cosa ti serve
Place the projector so that the bottom side is facing upwards
Remove the eight screws pictured from the bottom of the device.
Open the cover.
