Salta al contenuto principale
Epson EX90 Air Filter Replacement
Ryan Davis
Ryan Davis e 2 altri collaboratori
Ultimo aggiornamento il May 13, 2022
2 - 3 minuti
Molto facile
Introduzione
Vai al passo 1
Use this guide to replace the air filter in your Epson EX90 projector.
A clogged air filter can cause overheating and damage the projector. When the filter needs cleaning, the projector will display the message “The projector is overheating. Make sure nothing is blocking the air vent, and clean or replace the air filter.”
The official User Guide for the Epson EX90 can be found here.
  1. Epson EX90 Air Filter Replacement, Air Filter: passo 1, immagine 1 di 1
    • Turn off the projector and unplug the power cable.
  2. Epson EX90 Air Filter Replacement: passo 2, immagine 1 di 1
    • Place the projector so the bottom is facing upwards.
    • Remove the air filter from the bottom of the device by sliding it out of its socket.
    • Gently clean off any dust or debris (or purchase a new filter for replacement).
Conclusione
Ryan Davis
Membro da: 03/30/22
85 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 126
