Emson Star Wars R2-D2 Water Tank Valve Replacement
Introduzione
Vai al passo 1The valve allows water to move through the device in order for the water to be vaporized and ultimately emitted. If the device doesn't emit vapor or leaks, the water valve may not be functioning properly. It may also be possible that it isn't attached tightly enough. We will demonstrate the steps to take out the valve and then replace it.
Cosa ti serve
Altre 2 persone hanno completato questa guida.
