Salta al contenuto principale
Eclipse 180BL LCD Screen Cover Replacement
Thomas Schwarz
Thomas Schwarz e un altro collaboratore
Ultimo aggiornamento il 6 gen 2016
5 minuti
Moderato
Foto Azione
Necessarie Più Immagini
Passi mancanti
Introduzione
Vai al passo 1
The LCD screen cover is protection for the easily damaged LCD display. This screen cover is vital to the life of your device.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: passo 1, immagine 1 di 3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: passo 1, immagine 2 di 3 Eclipse 180BL LCD Screen Cover Replacement, LCD Screen Cover: passo 1, immagine 3 di 3
    • To start, remove the two screws located at the bottom of the device.
    • The two screws can be removed using the PH00 head located in the iFixit Repair ToolKit.
    • Both Screws are 1/8 inch in length.
    • Remove the case, and with the Spudger, apply force to the USB port to remove the inner component.
    • Be careful, as releasing the tension will cause all parts to become loose and separate.
  2. Eclipse 180BL LCD Screen Cover Replacement: passo 2, immagine 1 di 3 Eclipse 180BL LCD Screen Cover Replacement: passo 2, immagine 2 di 3 Eclipse 180BL LCD Screen Cover Replacement: passo 2, immagine 3 di 3
    • The LCD screen cover is placed into its slot after all the inner components are replaced.
    • Get the new screen cover, and carefully place in alignment with the outer shell.
    • Be sure that the screen fits perfectly, as dust getting in the screen will cause pixels to die.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 613
