Dyson v6 Absolute Cyclone Replacement
Introduzione
Vai al passo 1If there are issues with the suction of the Dyson v6 Absolute, the cyclone may have to be cleaned or replaced.
Cosa ti serve
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Use tweezers to pinch the white clips together.
Widely hold the tweezers apart to get them to reach between the two white clips.
Because the space is tight between the cyclone and the main body, pinching the white clips may require additional effort.
You can use spudgers to push the individual white tabs inward. Or, put the unit upside down and use two spudgers to push them inward.
The cyclone will pop out but will require some pulling to clear the main body. There are no wires.
Tilt and pull the main body away from the cyclone.
There may be a loud snap when the main body separates from the cyclone.
Do you have any idea how to disassemble the main body (aside from removing the battery pack)? I accidentally waterlogged it and wanted to check for water damage
Use the spudger to remove the cyclone.
Start at the small opening beneath the place where the cyclone connects to the main body.
Work the spudger around the rim of the red screen filter.
You will hear popping noises.
Remove the filter screen cover away from the cyclone.
Pull down on the black tube inside the cyclone body to remove it from the cyclone.
You can go deeper. There’s four more screws that take a very narrow screwdriver that split the top vortex section apart.
Altre 17 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti3Commenti sulla guida
Very helpful presentation. Reassembly was fiddley as the new cyclone was not broken and needed a very firm waggle and push to engage with the motor body. The white clip is not easy to grasp at the same time as the body and the cyclone.
I found three small broken black plastic pieces under the white clip- from the lugs of the old cyclone - that had to be removed, with tweezers, before assembling the body and cyclone.
