Salta al contenuto principale
DualShock 4 (CUH-ZCT1U) Speaker Replacement
Cosa ti serve
  1. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Check your controller model: passo 1, immagine 1 di 1
    • Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
    • If you have the second generation DualShock 4, model CUH-ZCT2U, use these guides.
  2. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Unfasten the rear case: passo 2, immagine 1 di 2 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Unfasten the rear case: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Microfiber Cleaning Cloths
    $3.99
    • If you need to stabilize your controller during this repair, lay it on a soft surface such as a microfiber cloth.
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
  3. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the L1 button: passo 3, immagine 1 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the L1 button: passo 3, immagine 2 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the L1 button: passo 3, immagine 3 di 3
    • Use an opening pick to pry each corner of the L1 button from the front case.
    • Cover the button to prevent it from ejecting out of your workspace.
    • Remove the button.
  4. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the R1 button: passo 4, immagine 1 di 1
    • Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
  5. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Unclip the rear case: passo 5, immagine 1 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Unclip the rear case: passo 5, immagine 2 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Unclip the rear case: passo 5, immagine 3 di 3
    • Six plastic clips secure the rear case to the front case. The next four steps demonstrate how to release these clips before you can open the controller.
    • Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
    • Slide your pick toward the handle and pry up to release the first clip.
    • Repeat this procedure on the other side of the controller to release the second clip.
  6. DualShock 4 (CUH-ZCT1U) Speaker Replacement: passo 6, immagine 1 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement: passo 6, immagine 2 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement: passo 6, immagine 3 di 3
    • Two more clips secure the rear case near the extension port and the headphone jack.
    • Insert your opening pick between the front case and rear case at either side of the ports.
    • Twist your pick to unclip this section of the rear case from the front case.
    • If the rear case feels stuck, insert and twist your pick from different angles.
    • Don't open the controller yet, as it's still held together by two very delicate clips near the triggers.
  7. DualShock 4 (CUH-ZCT1U) Speaker Replacement: passo 7, immagine 1 di 1
    • The final two clips are very delicate, and must be disengaged from inside the controller. If you break them, don't worry—it won't affect this repair or your controllers functionality.
    • Locate the clips by looking through the gap above the R2 or L2 buttons.
  8. DualShock 4 (CUH-ZCT1U) Speaker Replacement: passo 8, immagine 1 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement: passo 8, immagine 2 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement: passo 8, immagine 3 di 3
    • Insert the point of a spudger through the gap above the R2 button and push the retaining clip outward.
    • While pushing the clip outward, slowly pull the rear case away from the front case until you feel them separate.
    • Don't fully open the controller until each of the R2 and L2 clips have been disengaged.
    • Repeat this procedure for the clip near the L2 button.
  9. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the rear case: passo 9, immagine 1 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the rear case: passo 9, immagine 2 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the rear case: passo 9, immagine 3 di 3
    • Press the R2 button and slide the rear case over it.
  10. DualShock 4 (CUH-ZCT1U) Speaker Replacement: passo 10, immagine 1 di 1
    • Press the L2 button and slide the rear case over it.
  11. DualShock 4 (CUH-ZCT1U) Speaker Replacement: passo 11, immagine 1 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement: passo 11, immagine 2 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement: passo 11, immagine 3 di 3
    • Flip the rear case over the top of the controller and lay it down, being careful not to strain the interconnect cable.
  12. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Disconnect the interconnect cable: passo 12, immagine 1 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Disconnect the interconnect cable: passo 12, immagine 2 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Disconnect the interconnect cable: passo 12, immagine 3 di 3
    • Use tweezers or your fingers to remove the interconnect cable by pulling its blue pull tab straight out of the socket.
    • During reassembly, reconnect the cable with its blue pull tab facing the outside of the controller.
  13. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Disconnect the battery: passo 13, immagine 1 di 2 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Disconnect the battery: passo 13, immagine 2 di 2
    • Use tweezers or your fingers to grab and disconnect the head of the battery cable from the motherboard.
    • Only pull on the head of the connector—don't pull on the cable itself.
  14. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the battery: passo 14, immagine 1 di 1
    • Remove the battery.
  15. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the reset button extension: passo 15, immagine 1 di 2 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the reset button extension: passo 15, immagine 2 di 2
    • Grab and remove the reset button extension from its recess in the battery bracket.
  16. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the battery bracket: passo 16, immagine 1 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the battery bracket: passo 16, immagine 2 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the battery bracket: passo 16, immagine 3 di 3
    • Locate the two clips securing the battery bracket to the motherboard.
    • Insert the point of your spudger into the opening behind the right bracket clip.
    • Depress the clip to disengage it from the motherboard.
    • Lift up the right edge of the battery bracket.
  17. DualShock 4 (CUH-ZCT1U) Speaker Replacement: passo 17, immagine 1 di 2 DualShock 4 (CUH-ZCT1U) Speaker Replacement: passo 17, immagine 2 di 2
    • Insert the point of your spudger in the opening behind the left bracket clip.
    • Remove the battery bracket.
  18. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Disconnect the touch pad: passo 18, immagine 1 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Disconnect the touch pad: passo 18, immagine 2 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Disconnect the touch pad: passo 18, immagine 3 di 3
    • Use the point of your spudger to flip up the locking flap securing the touch pad cable ZIF connector.
    • Use tweezers or your fingers to disconnect the cable using its blue pull tab.
  19. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Unfasten the motherboard: passo 19, immagine 1 di 1
    • Use your Phillips screwdriver to remove the 6.4 mm screw securing the motherboard.
  20. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the motherboard: passo 20, immagine 1 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the motherboard: passo 20, immagine 2 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the motherboard: passo 20, immagine 3 di 3
    • Be careful not to strain the vibration motor cables. Follow this guide to re-solder the vibration motors if they break off the motherboard.
    • Lift the motherboard from the midframe.
    • Guide the analog stick covers through their cutouts in the front case.
    • Flip the motherboard over the bottom of the controller, leaving the vibration motor cables attached.
  21. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Peel up the sticker: passo 21, immagine 1 di 2 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Peel up the sticker: passo 21, immagine 2 di 2
    • Use tweezers or your finger to peel up the left half of the speaker's sticker.
  22. DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the speaker: passo 22, immagine 1 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the speaker: passo 22, immagine 2 di 3 DualShock 4 (CUH-ZCT1U) Speaker Replacement, Remove the speaker: passo 22, immagine 3 di 3
    • Insert your tweezers into the gaps in the corners of the speaker's metal backing.
    • Pry up to loosen the speaker from the front case.
    • The speaker is adhered to the front case.
    • Remove the speaker.
Conclusione
Clay Eickemeyer
Membro da: 09/19/22
95.653 Reputazione
466 Guide realizzate
Guide Team Membro di Guide Team
Staff
10 Membri
15.803 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 87
Tutti i Tempi: 2,827
