Disassembling Nerf Recon CS-6 Shell
Introduzione
Vai al passo 1This is a prerequisite to replacing any other piece. This guide involves removing most of the screws in the shell and splitting the gun along the middle seam.
Cosa ti serve
Strumenti
Pull slide back.
Pull backwards on release buttons and slide magazine out.
Push slide back forward and pull trigger.
Use the Phillips #0 Screwdriver to remove these 9 screws.
All screws marked in red are 9.6 mm Phillips #0 screws.
Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
Pull slide back to reveal more screws.
Remove these 2 screws.
Push slide forward.
Pull trigger to release compression of the main spring.
Screws are 9.6 mm Phillips #0.
Remove the screws on the plunger cap.
Tug the plunger cap off.
Remove the 2 screws on the slide.
Pull the gun apart at the middle seam.
Altre 12 persone hanno completato questa guida.
2Commenti sulla guida
Does anyone have a spare spring for this gun I am missing mine
very useful, thanks!
My priming bar is stuck how do I fix this?
Ethan - Replica
