DigiTech RP70 Footswitch Replacement
Introduzione
Vai al passo 1If one or both of the footswitches works inconsistently or not at all, refer to this guide.
Cosa ti serve
Strumenti
Pull firmly on the binder clips that are holding the footswitches in place to remove them.
Altre 2 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti1Commento della guida
So what is the fix? Replacing both foot switches with new ones? Or removing them and reinstalling them will fix the problem of them not working at all? What’s Step 7? If you stop after completing Step 6 you now just have a casing without foot switches. What will fix the problem of them not working qt all after removing the foot switches?
