Salta al contenuto principale
Desktop PC RAM Replacement
David Lennon
David Lennon e 5 altri collaboratori
Ultimo aggiornamento il 6 apr 2023
15 - 20 minuti
Moderato
Introduzione
Vai al passo 1
RAM(Random Access Memory) is a very fast type of memory. It stores short term information so that it can be accessed quickly. Replacing or upgrading RAM in a computer can help a computer run more quickly and smoothly.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Desktop PC RAM Replacement, Left Panel: passo 1, immagine 1 di 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
    Dave Ellefson - Replica
    This is correct.
    DistroHopper39B -
  2. Desktop PC RAM Replacement: passo 2, immagine 1 di 2 Desktop PC RAM Replacement: passo 2, immagine 2 di 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC RAM Replacement, RAM: passo 3, immagine 1 di 1
    • Unlock the RAM by pressing down on the tabs from either side of the RAM that are securing the RAM to the socket.
  4. Desktop PC RAM Replacement: passo 4, immagine 1 di 1
    • Carefully remove the RAM sticks from the computer casing.
    • Repeat the above step and this step as necessary. Some computers could have many sticks of RAM.
Conclusione
  • When replacing the RAM, place the replacement into the RAM slot and lock the tabs in.
Altre 53 persone hanno completato questa guida.
David Lennon
Membro da: 04/14/15
10.126 Reputazione
10 Guide realizzate
Cal Poly, Team 4-5, Maness Spring 2015 Membro di Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Membri
45 Guide realizzate
4Commenti sulla guida
can you remove the heat spreader on a corsair vengence led ram?
scar0134 - Replica
very interesting
maciekErd123 - Replica
how to determine the speed
benzy aceware - Replica
how can i differentiate between types of rams
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 33
Tutti i Tempi: 7,714
